When first turning the unit on after a few months the water was dripping out into the living room a lot. About 40 minutes the dripping stopped. How is the water suppose to drain from this A/C ?
SOURCE: Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
SOURCE: Window unit is not draining, tray is filling with water
Remove the unit from the housing. Using a special cleaner, called coil cleaner which you can purchase at any AC shop clean the coils, this should eleminate the problem.
SOURCE: Intertherm Air Handler Coil leaking water
replace it it's junk - going to do that this time because this is the fourth year of the same problem on the hottest days this intertherm junk downflow ac unit condensates where it will not and con not be captured by the pan - built by relatives of the guy who designed the titanic -
SOURCE: Condensation water is not draining properly on
Yes,remove the ac unit from the window,and clean it out with a water hose out side,remove all debris from inside the unit,and tilt water out of unit.Make sure there is nothing in the way of the drain,and when the unit is put back in the window,make sure it has a very good tilt outward so the water will for sure flow outside,not in.If this was helpful,please rate,thank you.
