Question about Vestax QFO Turntable
I'm changing the fader, but not I only get sound from the left channel. Why?
I am replacing the crossfader, but now I only get sound on the left channel. What is going on and how can I fix it.
2 Suggested Answers
  • 133 Answers
SOURCE: Sound only coming out opf left channel
Probably there are dirty contacts inside the assign switch, also it could be a bad solder contact on the switch or there around.
The switch can either be removed and cleaned or replaced.
Cleaning is a bit delicate procedure, but can actually be done, you need to take the switch apart, taking care not to damage any of the parts, then you need to clean the inner contacts and the contact making clamps with some fine sandpaper.
Be sure to put everything back together as it was otherwise the switch may not work properly or it may not work at all (be gentle with the contact making clamps, they can easily be damaged / squashed).
It could also be a problem with faders or preamps, but i would take a look at the switch first.
regards
3rq8 (Triarcuate)
Posted on Aug 02, 2009
HOw do you use the crossfader if all your music is coming through one port???
The crossfader is to gently fade from one source to another. If you only have one, the crosfader isn't useful... it would act like a plain fader with one side being dead and the other at full volume.
Aug 06, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
My dj mixers crossfader is not sensitive in the right range. i am looking for a replacement which is either adjustable or sensitive throughout. vestax mixer mdm 410
Hi Ray
Sounds like the fader has reached the end of its life. It should fade smoothly from one side to the other with equal audio from both lines in the middle. . You can get adjustable rate faders, but not for this model. if you do a search for a replacement (click here) there are plenty of places around the world to source one from. They are easy enough to change, overpriced in my opinion, but they dont miss you when it comes to replacements. Changing the fader will fix your problem I am sure. Thanks for using fixya. Good luck
regards
robotek
Nov 09, 2008 | Audio Players & Recorders
My Behringer DX626 Mixer got beer spilt on it, and i got it back from repairs today, but it seems as channel 2 / the crossfader still doesnt work. e.g i have crossfader in the middle, and both channel 2...
sounds like the beer short circuited the equipment, the people who tryed to fix it didnt do a good job seems like, try taking it apart an use a cue tip an find any beer fragments that could remain in the unit, that mite be the problem
Oct 24, 2008 | Audio Players & Recorders
PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Aug 09, 2008 | Peavey 32fx USB 32 Channel Mixer
Whats a crossfader
The cross fader switches the source from one input to the other input. D.J.'s use them to fade from one song into the next one they are going to play when using 2 different turntables or 2 different cd players..
You did say in your question that you needed a crossfader.
Hope this helps Brittany.
What's the 721 stand for?
Dave
Jul 01, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
Correct set for mixer and pioneer cdjs mk 2
Try turning you 'Crossfader Switch' from "OFF" to "ON"
Sep 26, 2007 | Pioneer CDJ-1000MKII CD Player
Vestax QFO Turntable Logo
29 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
