Question about Asko T701 Electric Dryer
Runs for 2 mins. then stops, push reset button & will run for 2 minutes & stops again
Asko dryer runs for approximately 2 minutes and will stop, push reset button and will run for 1-2 minutes and stop again. This is a stackable unit - what could be wrong? If it's a fuse where are fuses located, if it's a sensor where is that located and where could we find parts for it.
  • 3 Answers
How long have you had the dryer? It sounds like it is overheating, and the most likely cause is accumulated lint. You can check this by removing the round plastic covers on either side panel. Just rotate them and they will pop out. Clean out any lint you see in the air channels and replace the covers.
Also check your ducting - it may be partially or fully blocked by something. You could test this by disconnecting the ducting, then running the dryer to see if it still shuts off. (Prepare for some loose lint flying out in this event.)
Posted on Jun 23, 2009
LEC8858EQ0 starts and then shuts off
You have a problem with the motor overheating. Replace the motor and you should be good to go. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | Whirlpool Dryers
Overheating
What is this an asko? It means your vent is clogged or improperly connected. If its an asko, one of the vent covers may have popped off because those have 2.
Jan 24, 2012 | Dryers
I have an Asko 7305 Dryer that keeps tripping the fuse. When I put a load in to dry, it will run for a few minutes, then stop. I push the black button in the back and it will come back on for a few, then...
either the motors overloaded from clothes load size,the motor bearings are getting tight from lack of lubrication, or the dryer heating element is beginning to short out to the case and grounding itself and tripping the fuse
Jul 04, 2011 | Dryers
I have an asko T760 Butterfly dryer. It is stuck on P2 but will not run. I shut off the unit, turned back on. The LCD flashes between P1-P4 and what they are, such as extra dry, dry, normal dry, & iron...
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Apr 26, 2011 | Asko T761 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Dryer overheats and shuts off- vents have been cleaned and button on back has not reset
Common problem.
You probably need to clean
your dryer vent. Dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint. You can check the air-flow by going outside where the vents terminate. What's probably happening is on sensor dry, there's a moister sensor that tells the machine to shut off when there's no moister. The hot is is being pushed back into the dryer and confusing the sensor. That's why it's working on timer dryer because that option bypasses the moisture sensor.
I'm pretty sure that's it. Good luck.
Apr 15, 2009 | Asko T731 Electric Dryer
Asko T701 Dryer - Dryer Start Button
This would have to be your door latch, in my opinion. The door simply is not holding in the button.
Dec 07, 2008 | Asko T701 Electric Dryer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Feb 08, 2008 | Asko T761 Electric Dryer
Asko T701 Electric Dryer Logo
579 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
