Question about Refrigerators
The light bulb in the refrigerator (bottom) went out on Saturday, shortly after I felt cold air coming out and heard the louder than usual sound from the refrigerator section. So far the freezer (top section) seems to be working. I feel outside the refrigerator is too cold as if cold air is coming out, and the inside was not as cold as it should be. And the ice maker in the freezer has not worked for awhile.
  • youngyunsumm Jun 01, 2009
    Thank you for your advice. I just tested with a dollar bill, and the door seems to hold it OK. I am still wondering what caused the light bulb pop. However, I am pleasantry surprised that the refrigerator feels cooler for me to leave now.
    I would still appreciate if you could figure out why the ice maker stopped making ice. Someone said the water line might be clogged. What do you suggest?
    Than you.
    Brigadier General:
  • Refrigerators Master
  • 3,614 Answers
If you find the unit was not completely cooling inside and sometimes its not workin this could be due to problems with the door. Ideally, the climate inside a refrigerator would never be broken, and the unit could maintain a steady temperature all the time.
Sometimes it happen that the refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply.
You can test it by placing a dollar bill between the gasket and the door jamb by closing the door. Pull out the $ bill, if it gives some resistance, means the gasket works properly. If the bills comes right out, or fall out, this means that you have a faulty door gasket and you should replace.
Test the door on several locations around the door to check the door for leakage.
Hope this initial info helps.
Let me know for further clarifications
Posted on Jun 01, 2009
Tfx28pbba
Actualy, it sounds like you merely caught it right when it went into defrost cycle. If it's a non-electronic (non-chinese) model, it probably has an electro-mechanical timer for the defrost which you can manually advance until the compressor comes back on.
Otherwise, just leave it plugged in and set at the default temperatures until it comes back on of its own accord. Defrost time could be in the neighborhood of 20 - 30 minutes. This can occur 3 - 4 times in a 24 hour period.
May 27, 2014 | GE Refrigerators
1983 ranger turn signal lights flash quickly on both sides. Hazard lights work. Steering wheel felt locked and heard a breaking sound that seemed to come from the steering column.
fast flashing usually means a bulb is burnt... have you checked them all ??? or did you wire in a trailer plug and did something wrong ???
Dec 28, 2013 | 1983 Ford Ranger
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Freezer not cold
If Tried to lower temp and still not working it could be your thermostat. i had mine checked and it a wire to my thermostat was cut.
Feb 26, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
MAYTAG MBB1952HEW - Bottom-Mount
I have this exact problem...was there a solution? Frost is causing bottom freezer door not to work, when I remove the frost, the light comes on. The gasket looks fine. Any Ideas?
Aug 14, 2008 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer just not getting cold enough. Freezer fan is running. Gasket, I thought was the original problem, has been re aligned. Light switch works and the light goes off when freezer is closed. Cold air is...
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
May 05, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
