Question about Sony PlayStation® 3 (60 GB) Console
Network problem i cant access playstation network its all setup but it sais its dissconected so how do i connect? also i'm using wireless network
    Problem Solver:
  • 17 Answers
Check if your wireless network is connected properly
Posted on Jun 01, 2009
How do I conect to the internet to play games
Below are instructions for connecting the PS3 to a wireless network (Wi-Fi) using the [Easy] setting. For other network connection options, see How to connect the PS3 to the Internet.
Text walkthrough
Power-cycle ALL network equipment.
Turn off (unplug) all of your network equipment, including any wireless access points, routers, Voice Over IP (VOIP) modems, and broadband modems for two (2) full minutes. See How to power cycle PlayStation 3 network devices for more details.
Make sure that all settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the PlayStation 3. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
Confirm that an Ethernet cable is not connect to the PlayStation 3. If the Ethernet cable is plugged in, the PlayStation 3 will automatically attempt to connect via the wired connection.
On the XMB home menu, go to (Settings) > (Network Settings) and press the button.
Then go to (Internet Connection) and select [Enabled].
Then scroll down to (Internet Connection Settings) and press the button.
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
Select [Easy] and press the button.
When prompted for which type of connection method, select [Wireless] and press the button.
Under WLAN Settings, select [Scan] and press the button.
If you own a wireless access point that supports AOSS (AirStation One-Touch Secure System), then you must select [Automatic]. These wireless access points are commonly made by Buffalo, Inc. AOSS will automatically configure the necessary settings. Follow the on screen prompts to complete the setup.
You will see a list of access points within range of the PlayStation 3. From the list, pick your SSID and press the button.
If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
On the next screen, confirm the SSID then press the right direction button to continue. If you press the button, you will edit the SSID.
Select the security setting that you want to use and press the button.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
If you selected a Security Setting, enter your security key.
Press the [Start] button to exit the onscreen keyboard.
Press right on the directional pad to proceed to the next screen.
The encryption key is displayed as a series of eight [*] no matter how long the key may be. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
Once you have entered all the information, a list of settings will be displayed.
Press the button to save these settings.
Depending on the network environment, additional settings for PPPoE, proxy server, or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
Press the button to test the connection.
When the test is complete (usually less than a minute), it will display the results ("Succeeded" or "Failed").
If you have successfully connected to your network, congratulations, you have completed the network setup process
Aug 15, 2012 | Sony Playstation 3 (PS3) Console
Tip
How to connect a playstaion 3 to the internet
here are 2 ways to connect your PlayStation 3 to the Internet; using a wired (Ethernet) connection or through a wireless connection. <img src="ps3_connection.jpg" /> <br /> <span>1. Wired Connection</span> 1. Make sure that your PlayStation 3 is connected to a broadband-enabled network using an Ethernet cable.<br /> <br /> <img src="full_setting.jpg" /> 2. Click <b> Settings </b> in the Home menu, then <b>Network Settings</b>. <br /> <br /> <br /> 3. Click <b>Internet Connection Settings </b><img src="network_icon.jpg" />. Then press the <img src="cross.jpg" /> button. <br />4. A message will pop up saying that you will be disconnected from the Internet. Choose <b>Yes</b>. Then press the <img src="cross.jpg" /> button. <br /> <br /> <img src="ps31.jpg" /> 5. When you are given the choice of connection methods choose <b>Wired Connection</b>.<br /> <img src="ps35.jpg" /> 6. Choose <b>Easy</b> - the basic settings are automatically set. <br /> 7. Now click <b>Save</b>. <br /> 8. If you want to you can now test your wired connection by clicking <b>Test Connection</b>. Your PlayStation 3 will now try and connect to the Internet. If the connection isn't successful you should follow the instructions which will appear, to check your settings. <br /> <span>2. Wireless Connection</span> 1. Click <b> Settings </b>in the Home menu, then Network Settings. <br /> <img src="full_setting.jpg" /> 2. Click <b>Internet Connection Settings </b><img src="network_icon.jpg" />. Then press the <img src="cross.jpg" /> button. <br /> 3. A message will pop up saying that you will be disconnected from the Internet. Choose <b>Yes</b>. Then press the <img src="cross.jpg" /> button. <br /> <br /> <img src="ps31.jpg" /> 4. When you are given the choice of connection methods choose <b>Wireless Connection</b>. <br /> <img src="ps32.jpg" /> 5. Now choose <b>Scan</b>. Your PlayStation 3 will now search for any available access points and show these in a list. <br /> Note: Some PlayStation 3 models have an 'Automatic' option, which if followed will complete the required settings for you automatically. Simply click on <b>Automatic</b> if the access point you are using supports automatic setup. <br /> <img src="ps33.jpg" /> 6. From the list of access points choose one which you'd like to use. <br /> <img src="ps31.jpg" /> 7. Check the SSID for the access point, press the right button. If you don't know what the SSID is then you should contact the person who setup or runs the access point for more information. <br /> 8. Select the security method necessary, press the right button. <br /> <img src="ps34.jpg" /> <br /> <br /> 9. Enter the encryption key. This will be shown as a series of asterisks (*). If you don't know what the encryption key is you should contact the person who setup or runs the access point for more information. <br /> 10. Now press the <b>right</b> button. <br /> <img src="ps35.jpg" /> <br /> 11. Choose either <b>Easy</b> or <b>Custom </b>and adjust the settings. <br /> <ul> <ul> <li> <b>Easy</b> - the basic settings are automatically set. </li> <li> <b>Custom</b> - you will need to enter the settings manually. </li></ul></ul> 12. Now click <b>Save</b>. <br /> 13. If you want to you can now test your wireless connection by clicking <b>Test Connection</b>. If the connection isn't successful you should follow the instructions which will appear, to check your settings. <br />
on Mar 22, 2011 | Video Game Consoles & Games
Please can some one tell me directions on how to get to my wep key so i can set it or reset it ive had psp3 for two months and cant enjoy what every one else is and my wife said if i cant get it to wrk ex...
first of all, WEP stands for "wireless encryption protocol" and the WEP KEY is the password required to access an encrypted wireless (wifi) network. the key is set and modified via a console that you access via a web browser and is hosted on the router.
it seems to me that you have a playstation 3, with a wireless capability and you wish to connect it to your router and are being asked what the WEP KEY is so that you can connect to the network.
i can not tell you what the WEP KEY in your case is, because it can be set to anything that you want.
you need to access your router and check what the key is, it is the same key that your computers and smart phones use to access the wireless network (wifi) in your home.
Nov 05, 2011 | Sony Playstation 3 (PS3) Console
I cant get a wpa key.it always tells me wpa key has timed out or is not correct
Thank you for using Fixya!
The WPA key can be found your router's setup page or configuration page (under wireless settings).
If you do not know how to access your router's setup page I would suggest contact your router's manufacturer to assist you on getting the WPA key. If you are connecting to other peoples wireless network then I'm afraid that is not possible unless you can ask them to provide you the key.
You can also go to www.portforward.com, to know on how to access router's setup page for different brand and model.
Hope this helps.
Thank you,
stif_nec
May 22, 2010 | Sony PlayStation Portable (PSP) Console
I cant connect to the internet
Playstation 3: How to setup your Internet connection This article helps you in setting up the Internet connection for Playstation 3 To enjoy the online capability of Playstation 3, you need to connect it to the internet. You can do it in two ways:
  1. Wired Connectivity.
  2. Wireless Connectivity.
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Back to top
Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust the network settings. These settings may change depending on the type of access point and the network environment you are in.
The following instructions apply most of the network configurations.
  4. Select "Wireless", press the x_button.jpg button.
  5. Select "Scan", press the x_button.jpg button.
    The system will search for access points within range and display them as a list.
  6. Select the access point that you want to use, press the x_button.jpg button. (An SSID is a code or a name that is assigned to the access point. If you have no clue which SSID to use or if the SSID is not displayed, contact the person who set up or maintains the access point.)
  7. Confirm the SSID for the access point, press the right button.
  8. Select the security settings as necessary, press the right button.
  9. Enter the encryption key, press the right button. (The encryption key field will display an asterisk (*) for each character you enter. If you do not know the key, contact the person who set up or maintains the access point).
  10. Select Easy or Custom and adjust the settings.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your provider
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
I am trying to setup a wireless connection from playstation 3 to my PC. I have netcomm 3G wireless router. When I access the playstation 3 menu to change to wireless connection, it scans and reads the...
does it say the ssid of the netcomm if so just hit start start and accept the ssid then just use all the defaults to connect.
if the wireless is encrypted it may be asking for a network key and you have to find that. it would have been the wireless passcode that you set when setting up the router if it has one. by default there is not one.
Sep 26, 2009 | Sony Playstation 3 (PS3) Console
My router is detecting the internet but i cant get the internet on my computer. I cant connect to my router but it says that im connected with limited access. I have it hooked up through the router with a...
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Apr 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
+!trouble shooting!+
your PS3 is wireless so if you deffently have a wireless router you just need to set it up in your network settings on your PS3
Feb 11, 2009 | Sony Playstation 3 (PS3) Console
Ive got verizon wireless broadband for my lap top and cant seem to be able to get online with ps3
Can you provide more information?  The Verizon Wireless broadband access is for your laptop only.  In order for the PS3 to take advantage of it, you'll have to setup Internet Connection Sharing on your laptop. That way your PS3 can connect to your laptop via your laptop's wireless connection (in Ad Hoc mode since you don't have a wifi network) and access the internet via the VzW Broadband Access.
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
