Shutsoff after 2 minutes ...can't reset timer
13' sdtv #dtv1300a keeps shutting off after 2 minutes. it appears to be the timer but I can't reset it and i can't find the manual that came with it. Can yo help???......Ben
  • poppyjac Jun 01, 2009
    In my menu there is no timer option, only shutoff(on/off). i select it for off but doesn't help. when the sleep feature displays on the tv, i change the number from 120 to 0 but that doesn't help. it still goes back to 120 and it still shuts off after 2 minutes.
    Sergeant:
    Champion:
  • 223 Answers
Go into your menu and select timers, from there you should be able to disable all timers.
Posted on Jun 01, 2009
Who have purchased 2 (actually 3 but the other one was a different kind) utilitech 0050024 outdoor timers and both keep resetting to midnight on monday as of the power has gone out. All programmed info is...
Sometimes people get batches of bad timers.
However this timer does not show a program carryover, and does not appear to have battery for carryover. Although many new timer have a capacitor backup, it is unclear if the Utilitec offers this feature.
http://waterheatertimer.org/pdf/Utilitec-0050024-tower-stake-manual.pdf
Use reset button to clear memories, and then reprogram.
This timer has 2 modes: programmable or photocell
As a general rule, these timers come with 1 year limited warranty, but unclear who backs Utilitec warranty.
Buy two new timers from different Lowes store, and return defect in new package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 12, 2013 | Hardware & Accessories
I need to know what to set my dials/sttings on 1EJE8 Dayton Timer. What I am trying to do is sound an alarm when I hit reset the timer shuts off the alarm for twenty min before resounding
Question is unclear.
Help me break it down.
You want to push a button and sound alarm?
And then you want alarm to sound until you push button again?
And then you want timer to delay 20 minutes before sounding alarm again for an unknown amount of time?
What is the reset?
Add a comment and say what control you have wired to the timer and a clear 1-2-3 sequence of events and times for possible help.
1EJE8 is 10-function timer, and no manual appears on the internet July2011.
Magnecraft has same-similar timer, the 820 series.
Open following link for detailed manual with illustrations.
http://www.serelays.com/library/section5/105A_820_Series.pdf
Jul 14, 2011 | Amperite Dayton Solid State Timer On Delay...
My dryer keeps shutting off after a few 10 to 13 minutes...and clothes are not drying. An element was changed some time ago. it does heat up but keeps shutting down...is it the timer or element?
Turn the breaker to the dryer completely off and back on again. Also check that nothing is blocking the venting. Remove the vent hose and run the unit if you are not sure. Make sure the lint trap is cleaned first. It probably is neither element nor timer since it is heating and quits without the timer advancing completely.
Apr 05, 2011 | Maytag HYE3657A Electric Dryer
I have an HL- t50756 and it turns off every 10 minutes
Try to reset the lamp timer. To do this get the remote first shut off the TV. Then on the TV remote (not cable remote ect) press MUTE
then punch in the numbers 182 then POWER in that order, wait when the TV starts up the Factory meneu will appear go to Options press, then look for Lamp Hrs. to see how many hours you have on your lamp TV lamps last appox 2 years average use. 4,000 hrs. Try this, above where you see the hours go to reset or something like that and press to reset blub timer to zero. Your blub might still be ok, but the timer says times up and tries to shut off the TV thinking the blub is bad. By reseting the blub timer to zero the TV will think it's a new lamp. Until it really goes then no picture at all or gets very dark. Try this trick it might solve your problem.
Good Luck!
Oct 12, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung ht-x50 home theater system keeps shutting off
You have probably set the sleep timer. Here's how to switch it off: To cancel the sleep timer, press the SLEEP button until <OFF> appears on the display.
Jul 07, 2009 | Samsung Electronics - Others
Sansui 13" DTV1300 shuts itself off
My girlfriend had the same issue with her 1300a. We saw on another forum that they took off the extra AV panel and infared receiver, so we opened it up. We couldn't really find either, but when we tightened all the plugs up things seem to be working fine again. Back to watching the Lifetime channel :(
Mar 18, 2009 | Sansui DTV1300 TV
WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Jan 16, 2009 | General Electric WCVH6800J Front Load...
I have an RCA SDTV Model: 24V414T The TV shuts off by itself after 1-2 min. and turns on by itself in the next 1-2 min and the process goes on. Can anybody help with this problem. Thanks
i have an rca tv shuts off by itself lite only the standby power after 2-5 minutes you can turned it on and will off automiticaly pls. help me with my tv model 24v414t.
Sep 21, 2008 | Televison & Video
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
