Question about Relisys TL 700A (White) 17" LCD Monitor
Moniter problems my moniter keeps flashing up with with the moniter settings and i cant get it to go. the only ay is to turn it of and back on but it just comes back up. i thought it was a button stuck but it's not and i cant think what else it is. plz help
  • Uniqueen33 Nov 15, 2007
    The monitor settings keep popping up on the screen and it looks like it is scrolling through the setting options. Sometimes the on/off button works, sometimes not. The other buttons have little or no effect. It just started to happen. I haven't changed anything on the computer; no downloads, updates, etc. I would really prefer not to go and buy another monitor if there is a simple solution. Thanks!
  • Anonymous Jan 06, 2008
    Turned on, everything else works fine except the "brightness" window appears to be glued to the screen behind it all works well, Initially thought it was a stuck button have tried everything I know to clear it. The window cannot be moved and the exit and save function do now work. occasionally the progress indicator runs form 0 to 100
I just got this problem - i switched comp off then power on monitor then unplugged everything made a cup of coffee came back hooked it all up. switched power on and menu box was back - turned it off by power switch on the side and then back on after 5 seconds and it has not returned
Posted on Mar 08, 2008
  • 3 Answers
I have fixed this problem (I think). I noticed That if you hold the menu button down and swith the monitor off and on the box goes, as soon as you let the button go it appears again. So I have jambed the button in with a slither of plastic cut off an old credit card turned it off and on and it appears to be OK. If it holds up I will super glue the button down. Better than someone elses suggestion which was 'Buy a new monitor' very helpful!
Posted on Jan 29, 2008
  • 1,006 Answers
The monitor have a problem
just replace the monitor
Posted on Oct 24, 2007
My refridgerator leaks
either there is a pub hole in the giving on the ein or our just is not tightened enough at the connection. is there water ay the bottom if the fridge cause usually there is so reservoir to keep water cold ay the back boutin of the fridge. youre going to have to look for water and follow the trail. remember water cant flow upwards so lllllll for the leak above the highest place you find water
Jan 08, 2012 | KitchenAid Refrigerators
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Mogul Screen black
Press the soft reset button located right under the SD mini memory card its a small hole just press there with your stylus (pen)
Oct 26, 2008 | HTC PPC-6800 Smartphone
F1703 17" Keeps blinking each 4sec, but I can see the PC scrren
it is a stupid moniter I have ever seen...I have 4 monitors with same problem...given many times for use...
Sep 07, 2008 | HP Pavilion F1703 17" LCD Monitor
KDS Moniter
Have you checked your video card or adapter?
Check the settings on the monitor itself.
If you didn't find the problem go into system properties (windows logo + pause)/hardware/device manager. Expand monitor/right click and see if your new monitor is listed. Is there a yellow or red symbol next to it? This would mean a problem, then right click symbol/properties and error will be shown.
Could be a memory issue.
Don't forget to try a "working monitor". This will narrow it down a bit.
Jul 14, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
Relisys TL 700A (White) 17" LCD Monitor Logo
94 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
