Question about LG DLG2524 Gas Dryer
Stakcing Issue I have the new blue LG washer with the gas dryer stacked ontop. I have the washer sitting in a drain pan as it sits in the closet of my masterbedroom. When the washer hits spin cycle the set starts ocillating and clanging. I cant imaging that this is good. I need help. The combo is heavy as hell and in a tight spot so if I am to undo something I want to make sure I only have to do it once. The potential for collateral damage is high here.
  • 66 Answers
Take the drain pan out and leavel the washer and the dryer.
Posted on Dec 19, 2007
  • 248 Answers
   Front load washers require a rock solid floor.  Anything less will add to vibration and noise.  If you feel the washer spinning when standing in the room the floor is not solid enough.
   Make sure all 4 legs are solid on the ground and that they have the lock nuts tightened.  When unit is spinning try running a front leg up and down a little and see if this changes the sound.
Posted on Oct 23, 2007
SOURCE:
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Hi, We just moved into
On the bottom of the rubber seal, there is a drain hole. Check to see if it is clogged and clear it out if it has an obstruction.
Jan 01, 2011 | Washing Machines
Is there a trick to installing a stackable washer and dryer in a closet? the gas vent and gas line as well as the electricity must be installed when the dryer is in place.?
yup theres a trick.. the trick is to be able to fit behind the unit once stacked to make final connections then climb out and push the units back into the hole..
the main problem is not kinking or otherwise damaging the vent or the gas line when pushing the thing back, hence the climb over make the connections then climb out attack..
never had any luck trying to connect it up while out in the open then stuff it into the hole..
it can be done, just takes time, and patience..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | LG Dryers
F20 Error for Kenmore HE3 Gas Dryer
make sure your vent for the dryer isn't starting to get clogged or it may have a hole in it therefore hot moist air is getting in the closet instead of outdise
Sep 07, 2009 | Dryers
Water wont drain
check the drainage holes under the criper drawers are not blocked. There is also a hose that drops water into a tray ontop of the copressor which evaporates it. This hose can also become blocked
Aug 14, 2009 | Frigidaire FEX831CS Top Load Stacked...
Can you stack if they weren't designed for it?
ive seen people build there own stack unit. alot of techs will tell you no but ive seen this done and there has been no issue. just make sure your platform is strong enough to handle the tumble of the dryer during normal operation
Jun 24, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Roper washer will fill but does not spin/drain
Sounds like a lid switch. If it fills and just sits there, Im working on a tutorial for this. Dave www.washermd.com
Jan 13, 2009 | GE WSM2420T Top Load Stacked Washer /...
LG Gas Stacking Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
Stackable Washer will not drain.
check if there is a low humming noise when on drain. if so there may be a foreign object trapped in pump. otherwise have you checked filter?
Apr 02, 2007 | Whirlpool LTG6234D Front Load Stacked...
LG DLG2524 Gas Dryer Logo
91 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
