Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel gwl11 washer leaking and squealing
My gwl11 is leaking from the bottom and does not appear to be coming from the pump or the hose from the tub to pump, also it squeal loudly when it starts recirculating the water in the wash mode. It hangs up before it "kicks" into the recirculate mode.
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Posted on Jun 02, 2009
I have a GWL 11. Bought the washer and dryer and the same time in Feb. 2006. Dryer fell apart Feb 2009. 3 weeks ago the washers diverter valve failed, I ordered a new one and recieved it, washed one load of clothes and the drain pump failed, order it and have been waiting 2 weeks for the drain pump. They still do not have it in stock, Fisher Paykel or Sears. Tomorrow I go buy a Kenmore or Whirlpool.
Posted on Jun 05, 2009
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Hello my Fisher Paykel washer will go through the
clean the pump at the bottom of the washer (its the piece with the fan attached); also check the hoses at the pump
Jun 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking on my fisher paykel washer. does it
Hi, It is due to a split in the flexible hose from the bowl to the pump. When machine is working, the split opens and closes, but when not operating it can be closed up enough to prevent seeing it leaking. .
Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Squealing
more than likely going to be hard to get the pump it is on back order through the company
Jun 27, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 fails to drain
I had the same problem. After bailing out the water, I tipped the machine and saw a knee high panty hose caught up in the fan on the bottom. I removed that, checked to make sure the fan could spin freely, and viola! problem solved!
Jun 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Washer. Leaking from bottom. Doesn't appear to leak during wash cycle.
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Jun 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Leaking from pump
You need to replace that water pump and do it SOON. If you let this go, it is going to eventually short out that pump motor and take the expensive machine control along with it. The part you need is a 420325P and you can get one from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
Dec 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
837 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
