SOURCE: compressor short cycling
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
SOURCE: how many amps will a 15000 btu ac unit pull at
15,000 BTU stating current 18 to 20 amphs. And running amphs will be around 6.5 to 7 amphs.
SOURCE: my dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
