Question about Karcher PSI Electric Pressure Washer
Karcher k3.48 pressure washer appears to be seized up?
Pressure washer stopped pushing out high pressure water. The unit when turned on produced an electrical huming noise which sounds like the motor wants to work but the pump is seized up? Is this a common problem and which parts generally need replacing?
    Problem Solver:
  • 12 Answers
If the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Posted on Jun 18, 2009
  • stephen perkins Jun 22, 2009
    this is one of 3 things, either the motor has seized, the start cupasitor has failed ( white tube in elec box0 of the motor has failed,
    firstly check the motor has not seized, this should be free to turn on the cooling fan, if ok check the cupistor this should be intact and have no bulges of gray matter leaking from it, you will need a meter to test, if thease are both are ok,,then its bad news,, the motor has gone,, always try to start the motor with the hose off when fult finding stalls,,
Where is the inlet regulator on my karcher 3300 high pressure washer
no inlet pressure regulator as they work of mains pressure
the only pressure regulator ther eis works off the wand trigger
when the trigger is pulled the pressure in the line drops off and the regulator switches on the motor to produce high pressure
when the trigger is let off the regulator reads the pressure and shuts off the pump;or allows the pressure to by pass back to the inlet side of the pump
Oct 30, 2016 | Karcher Garden
Karcher k5.700 wont run continuously at high pressure
Your unloader or your packing could be cooked and these washers can be a pain to work on or to even find someone to work on them. Since it is a cheaper fix I would replace the adjustable nozzle on your wand first. Those are notorious for going bad. Then you have no pressure and you think your pump is bad. Most electric washers arent worth working on as the cost of parts and labor often exceed the cost of buying a new one. look on your manual for the unloader and packing or jsut go here. FIND PARTS FAST Good luck!
Feb 20, 2015 | Karcher Garden
Karcher 395 motor does not stop running
if your machine was factory fitted with 'total stop system' TSS and has always stopped in the past then it is an issue with many possible parts !
does the machinw still operate at full pressure ?
if the machine can produce full pressure then it only has to produce 20 % more to actuate the TSS piston. When the stop piston moves it presses against an electrical switch tjat breaks the circuit. Producing 20% more pressure requires that your machine has no water leaks in the pump, hose, trigger gun or lance. Once you release the trigger the path back from the trigger to the pump TSS piston must be fully sealed.....
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 11, 2013 | Garden
No high pressure water
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 01, 2010 | Karcher 1550PSI Pressure Washer
Soap doesn't dispense
There are different tips, In order for the unit to siphon the soap you need to use the tip that is for detergent. Its basically a tip that does not produce a high pressure it's more or less a soaker. Unit won't siphon under pressure. I hope this answer your question please rate the answer if it was helpful. Good Luck and have a great day. Jeff
Apr 04, 2010 | Karcher PSI Electric Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
My Karcher high pressure sprayer is delivering intermitant pressure.Every 15 seconds or so it developes high pressure for only about two seconds. Why is it not delivering a constant high pressure stream?
Check that the water supply is constant , it sounds like the pump might be pushing out more water than can be delivered , or it could be a dirty inlet filter
May 17, 2009 | Karcher PSI Electric Pressure Washer
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
May 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher PSI Electric Pressure Washer Logo
1,231 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
