I have replaced everything I can think of and car still wont start. It cranks but will not start.
SOURCE: Removing window crank
Push in on door panel as suggested & you may have to spin handle or tool, then feel it slide in to right spot (slot cut) & push tool & handle should release
SOURCE: cranks but wont start
May have dirt on crank angle sensor ,loose/damaged. Located usually close to bottomf pulley on engine.. Remember to keep it simple and check for the obvious first (fuel/pump? is emergency shut off tripped accidentally from towing ? Turn ignition on and have someone listen at fuel neck for pump operation. Check all fuses.
SOURCE: 2000 hyundai elantra car cranks but wont turn over
Did you scan for any trouble codes? Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on. You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. Afterward, we might be able to help you DIAGNOSE the problem and perhaps fix the problem.
SOURCE: 97 hyundai excel wont start just turns over, hot
check ignition coil current supply and or distributor contact point or condenser/ ur cars current supply fluctuate when engine is hot....
SOURCE: how to bleed hyundai excel radiator?
there should be a plug (small bolt) at the thermostat housing remove it while filling the radiator. replace it when coolant runs out without air pockets
