Clearing the jam is quick and easy; it's the fact that it keeps happening. I've tried shutting the machine off and also using 24lb paper (recommended by a copier repairman). If this is not fixable, how do I at least retrieve the faxes that are in memory?
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine:
Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine)
Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part).
Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.
Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
SOURCE: Canon MF4150 Duplex Printing Paper Jams
SOURCE: Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
SOURCE: cannon image class D880 System Error E000
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
SOURCE: My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
