Whirlpool gas range model SF388PEWWO. The oven will light and reach temperature. Then when needing to re light to maintain temp the igniter will not come on and the oven goes off. I have replaced ignitor but still have same problem. Should I replace the DSI board or gas shut off valve?
SOURCE: wHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
The flame sensor is dirty or bad.
When the unit does not sense flame after ignition, the gas valve shuts down the system.
They can become corroded or dirty, but usually just need to be replaced.
Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
http://www.whirlpool.com/custserv/email_form.jsp
SOURCE: Bake oven does not light. Igniter glows for many
The igniter needs to draw between 3.6 and 4 amps to open the gas valve even thogh it is glowing the resistance may not be the same . Check the amperage and then replace igniter
SOURCE: Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
SOURCE: The oven seldom lights. Igniter is working,
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
Check the temp sensor as this may be on the brink!
