Hello I'm trying to connect a Buffalo terastation(storage media) through the internet so that they can store files on it. I have no problem accessing it from anywhere except through a server that passes through a DFL-200 firewall. Now since this product is end of life i cannot get any support from dlink on this issue. I gave the terastation a static ip ex: 222.222.222.222 (public address)and the server which is at another site is behind that DFL-200 firewall with an ip ex: 192.168.1.10 and gateway of: 192.168.1.1 From home i was able to click on start, run then type the address like so to map it: ex: run:\\222.222.222.222 and was able to connect to it and map the drive.I did this at 4 other places to test and make sure i had no problem accessing it. Now when i try from that server i cannot connect to it in order to map the drive so they can back up their server to it. I tried reading the manuals that i found but am still not getting anywhere. I'm not sure if i have to configure a policy and then port forwarding or even if i'm doing this right. Can anyone please help me to figure out what needs to be done in order to allow that server to reach the terastation so i can map a drive to it and finally be able to backup their stuff on it. This is what the setup looks like: Terastation----vianet(isp)-----persona(isp)------DFL-200(firewall)---server Terastation ip:222.222.222.222 DFL-200: gateway:192.168.1.1 server ip: 192.168.1.100
  • jcoady
    jcoady May 11, 2010
    Is the DFL-200 set up in NAT or No-NAT mode?
    Scholar:
  • 34 Answers
I'm guessing that you have a routing issue caused by the address of your tera server not being on the right subnet. Typically, addresses like 192.168.1.10 will have a subnet mask of 255.255.255.0 which will cause problems when you have a statically assigned ip of 222.222.222.222. You would be best off to assign your teraserver within the 192.168.1.x range, but outside of the range dynamically assigned by the router. Typically, you can control which addresses are assigned by the router (say 192.168.1.50 - 192.168.1.100). Just make sure that the tera server is outside this range so that it does not duplicate another device. Make it something like 192.168.1.11 or 192.168.1.222.
Hope this helps - flub
Posted on Jun 01, 2009
Mac OSx 10.8 cannot search BUFFALO TS-8VH24TL/R6 24TB
Specs only indicate Windows. No iOS. Might be cause of the RAID configuration / software.
Though it does support HTTP and FTP protocols.
Nov 05, 2012 | Buffalo Technology - TS-8VH24TL/R6 -...
Tip
Buffalo Terastation
No need to enter Username and password in vista everytime you boot the computer
you can blame the security setting in windows vista -these decide the request /response authentication protocol used for the network login .The default setting for win vista NTLMv2 (NT lan manager version 2)
but the terastation still uses an earlier version of it .
The setting can be changed as follows :click tge start button ,enter "secpol.msc " in the search field and double click the progrma found .confirm the start of the console with "continue' .Finally ,double- click and open "security settings".then expand the "local policies" "security option" folder .In the following list select "Network security :lan manager authentication level".A dialog box open on double clicking it .At this point,switch to the "local security setting" tabthe default set option "send NTLMv2 respone only " to "send LM & NTLM -use NTLMv2 session security.if negotiated " .save the changes with "ok" and teraStation will start working again
on Apr 24, 2010 | Computers & Internet
Bootmgr is missing
if you can get hold of a windows installation disc, you can boot from it and use the repair option.
Sep 21, 2012 | Buffalo Technology BUFFALO WS-6V12TL/R5...
How to install antivirus in Buffalo Tsx40tlr5 Terastation
You have antivirus installed on this NAS system? You will want to look up the product manual for that product and see if it allows antivirus programs to be installed. Some NAS stations come with built in anti virus. You could even contact their support to get a list of "SUPPORTED" anti virus software. At which point, you will have to telnet or console into the data storage system and install the software. You could probably install the files through a CIFS connection but it would be best to contact Buffalo support as they can walk you through the proper steps.
Aug 05, 2012 | Buffalo Technology Buffalo Tsx40tlr5...
Buffalo LS CH1.0TL not recognised by computer on IP or USB
If you are using a Windows OS to access the drive, you will be unable to read the filesystem on this drive, as Windows cannot read XFS file systems which Buffalo uses.
Try downloading/booting off of a Linux live cd (knoppix, ubuntu, etc), they are free for download from their respective websites, and should be able to read that XFS partition.
May 05, 2011 | BUFFALO hop 1TB LinkStation Live Network...
I need to reset the IP address, subnet, etc, of my TeraStation 1.0TGL/R5, but I cant do with the nav tool on the computer. Is there any way to manually reset it? Thank You
click start run and type in cmd click ok when ms dos prompt up in that type ipconfig /renew then you will see the renewed ip address subnet mask etc
Apr 01, 2011 | Buffalo Technology TeraStation Pro...
My hardisk doesn't recognize in my computer but appear on device manager and disk managemnt
Hello raissateddy
Go to the Control panel and select " Folder Options \View " and check " show hidden files , folders and drives " .
Best regards ,
fanaudi .,
Mar 15, 2011 | Buffalo Technology Buffalo LinkStation Pro...
Unable to map server to storage media over the internet for back
Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly.
Check your configuration level and access policy.
If its a public server you have to place it in DMZ.
Check IP settings of the server. U may require a VPN tunnel
Rate if this is helpful
Thanks
Good Luck
Jun 01, 2009 | D-Link NetDefend DFL-200 Firewall
New Fan for buffalo terastation ts-1.0tgl/r5
just the fan, with 3 wires, as long as it has the 3 wires then you can adjust the speed... most fans do come with this 3 wires setup now adays
Apr 15, 2009 | Buffalo Technology TeraStation Home...
Buffallo terastation
How can you loose the password? if your that stoopid then i think you shouldnt own TS,or is it you have bought second hand only to find its password encrypted? either way if you cant read then you shouldnt own a TS instead why not see if you can swap for an external HD ;D
Jan 25, 2009 | Buffalo Technology TeraStation Home...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
