Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw has sat idle for about 2 year and won't start.
I have a Poulan 2300, it has not been used for over 2 years. I know it will not start (I tried), what can I do to get it up and going after it has sat for so long?
  • 90 Answers
Change the oil and spark plug
Posted on Jun 01, 2009
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Starts fine will sit and idle forever and never miss a beat, as soon as you try to use it,acts like its running out of gas
2 Cycle? Need to clean the carb! There are two needle vavle on most of those too. It could be out of adjustment but if it sat with gas in it, the carb is gummed up.
Oct 25, 2013 | Poulan Pro PP3416 16-Inch 34CC Gas...
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 14" Woodshark Poulan chainsaw. I put in
Poulan Chainsaws are pretty well all powered by two stroke engines. My best guess is that you have the fuel mixture incorrect (it should be a 1:40 ratio of oil to gas). if the fuel mixture is not the problem then your choke is messed up. If you haven't tried already try and find the sweet spot in the choke where it will run.
Mar 04, 2011 | Poulan 14" Chainsaw
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 08, 2009 | Poulan Garden
My Poulan chainsaw is hard to start and will not re-start once it is warm. Any suggestions besides junk it.
Spend $ 40 for a tune up at a local chainsaw seller/mechanic. Most Stihl outlets are very good. It sounds like carburation needs adjustment, but they also do a good visual inspection. Mine get done about every 3 years worth of use. HTH
Lou
Sep 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I own an 18" 42CC Poulan chainsaw. It's the kind Wal Mart sells. It's worked great for about five years. Today, the chainbrake stopped working. When I crank the saw, the chain runs. It was for no apparent...
5 years on a Poulan isn't bad. I think you are saying the chain rotates at idle. The idle may have crept up over the years, it can be tested and set to manufacturer's recommended speed by your friendly neighborhood chainsaw shop. There are springs on the centrifical clutch that occationally get tired, the same place can determine if that is your problem and replace them or show you where they are located so you can replace them. A good shop will be willing to help regardless of what they sell. HTH
Lou
Sep 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 335 chainsaw starts easily and then stalls
1. You will first want to check your fuel lines for cracks/breaks.
2. If they are o.k. then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure that the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Check the gasket and diaphragm for breaksor wear. (NOTE): If your carburetor guts, (Carb. Kit), are more than 3 or 4 years old, you might want to replace them while you have it apart.
If you need further assistance, just let me know.
Jim
Jun 10, 2009 | Poulan Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
632 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
