Question about Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
Kenmore 80 series gas dryer propane model # 11072802101 dryer heats up for about 5 min stays running but heat turns off- all vents clean
  • 2 more comments
  • Rinab Jun 01, 2009
    the ignitor does not glow again it stays black in there- what part # is th gas coil and my dryer is hooked up to propane does that make a difference- is changing the coil a easy fix for a dryer novice-
    sorry gave wrong info actually it glows ignites goes black glows ignites goes black several times
    after a bit coils continue to glow on and off but no flame
  • Rinab Jun 02, 2009
    Should i still replace the coils or do u think it is something else?
I HAVE A WHIRLPOOL GAS DRYER THAT SHUT THE HEAT OFF AFTER RUNNING FOR 10 MIN.
Posted on Jun 14, 2009
    President:
  • 1,136 Answers
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Posted on Jun 01, 2009
  • Victor
    Victor Jun 02, 2009
    Hi, You will need to replace the coils.
    Ignitor is tryng to light the flame but the coils will not opes gas calce.
  • Bill Malloy Jun 26, 2015
    Replace the coils same problem could it be thermostat vents are clear
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Have a kenmore 11072802101 gas dryer. it will heat for about 5 min & THEN BLOWS COLD.I replaced thermal fuse.IS IT THE REGULATOR?? OR THE OPPERATING SENSOR.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Dryers
Heat cuts out during cycle
Not one coil,both coils. Replace them both and make certain the exhaust vent is not blocked.
Aug 24, 2009 | Kenmore Dryers
Propane dryer. Can hear the heat kick on but dryer doesn't heat
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
May 31, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
342 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
