Question about Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle
Crossman Sierra Pro Air rifle
The rifle worked 3 times. Now it will not lock when you **** it by breaking the barrel the gun will not lock when you pull the barrel down the spring just pops the barrel right back up. how do i get it to stay locked???
    Scholar:
  • 88 Answers
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Posted on Aug 11, 2009
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman Optics
Crossman repair
I have a crossman pulse r78 and it will not shoot ,when you pull trigger it Gus windes oner spring do not egage
Dec 05, 2013 | Crosman Model 760 Pumpmaster Air Rifle
I have a crossman 1377 (177) cal pellet pistol. Is it ok to shoot BB'S in this gun? Does it damage the rifling in the barrel? Thanks, Gary
yes it safe to shoot bb,s in the 1377 pump pistol,i have 3 of them they actually shoot true'er and with more vilocity
Sep 19, 2011 | Crosman 1377 177 Single Shot Air Pistol
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
Jan 30, 2011 | Crosman Phantom .177 Caliber Break Barrel...
How do I adjust my scope on my Crossman bb/pellet rifle .177
Assuming the scope is ok, and the gun is ok, it must be the shooter, Not you but the stance, holding, bench rest, something is not consistent. If I was you, I would set up a big piece of cardboard at 15 yards, get the rifle on a beanbag or a bench rest, aim at a one inch spot in the center of the cardboard, shoot about 3 times, depending on where the pellet is hitting, move the adj knobs accordingly, do it again, 3 times, adj, as many times as it takes, get it centered, then, shoot it about 3 times at a clean plate, if it hits it's mark 3 times, then you can try it standing, and you should be able to build confidence in it so you know where it shoots, and won't be discouraged. Now if the rifle is bad, or the scope mounts loose, you will fight the thing all day and end up trashing it. I would blame the mounts first, then the scope, then the rust spot in the barrel, rare. If it is a break action rifle, you can set it up in a box with v's cut into it, look through the bore at the target, make sure it doesn't move, the scope should be looking at the same exact thing, if it isn't, something is wrong. You can set it up this way to start, and then fine tune it with pellets. Check it out, hope this helps.
Aug 01, 2010 | Crosman Adventure Rifle Scope 3-9X 50...
I Have a crossman .177 air rifle, that you have to pump, after the first pump you hear air leaking out of the barrell, how do you fix that?
Some air gun problems are an easy fix, some require extensive presses and jigs to move springs around. Most are not to messed with. I know, I have tried my best to repair an air rifle or two and had to send them back to the company to get them fixed. And there is nothing I can't fix, I have a big machine shop, been gun smithing for years and couldn't fix a little air rifle. Check out this website, it might help you, or steer you in the right direction. ,,,,,,,http://www.airguns.net/faq.php#faq1
Feb 17, 2010 | Crosman Optics
Will not chamber a pellet for Crossman 357 .177 cal pellet gun
http://www.pyramydair.com/site/manuals/Crosman-2100.pdf ,
Read this and make a decision based on the information contained within.
Feb 06, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
Mar 29, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crossman Phantom break barrell air rifle will not **** after breaking the barrell open. Any suggestions as to the problem?
The barrel pushes the piston back when you **** it.
The seer grabs the piston to hold it.
It sounds like you have an engagement issue between your seer and piston.
Often there are springs which hold the triger paul and seers in place. You may have lost a spring which isnt allowing your trigger mechanism to reset after the trigger is pulled. This results in the trigger being permanitly in the fired position.
Good luck and hope this gives you something to look for
Mar 10, 2009 | BSA Air Gun Scopes
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Feb 08, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle Logo
426 people viewed this question
Top Crosman Boating Experts
Neil
Level 1 Expert
yobo007
yobo007
Andrew Taylor
Andrew Taylor
Are you a Crosman Boating Expert? Answer questions, earn points and help others
