Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer does not dry
We have had our top loading dryer for about two to three years. This dryer never seems to dry the clothing. Even when I set it to "extra dry", it still is somewhat damp. It's very frustrating. Can you help please. Why am I paying for this help?
I had same problem. I constantly had to take the front off and push the reset button, sometimes 5 times in a load to reset the thermostat. I thought it was a faulty thermostat. I took the lint trap/cup out, removed the screw holding the large round white cover and was flabbergasted! The whole inside was stopped up with lint. Thourghly cleaned the inside and unstopped the completely clogged holes and replaced. Ain't the Internet awesome!
Posted on Jun 27, 2009
Lint can get past the lint scraper and glog the airway to the blower motor. This will increase you dry time. Review this links: http://fisherpaykelparts.net/partmanuals/DGGX1_US_96011-A.pdf Look at page 12, item 13. This piece has a mesh screen that can wear thru and allow the lint to escape the drum. I had this same problem. Go to this website and make sure you are working with the correct model. http://www.fisherpaykelparts.net/
Posted on Jun 03, 2009
We had the same problem with our dryer and the tech said that it wasn't drying because the vent hose was clogged and it needed to be cleaned. It is a safety setting on the dryer that keeps it from overheating. That is how many house fires begin. Hope this helps!
Posted on Jun 26, 2009
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
May be the timer and heating element seems to be faulty, And i don't want you to check it.. without proper precautions since its electrical equipment..
Please contact service person near by It takes very less time to service it..
Hope this info helps
Posted on Jun 01, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
The dryer takes three hours to dry a large load. It is almost one year old and it seems to take longer than it used to and the clothes don't actually get that hot anymore
is your dryer getting hot if so disconnect your dryer vent and run a normal load and if it drys that load in a normal ammount of time it is your vent pipe in the wall clogged
Mar 16, 2010 | Maytag Dryers
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Candy CMD146 Washer/Dryer
Is the dryer electric or gas? If electric, the heating coil may have burnt out. If gas, check gas supply and then gas ignitor. Good luck.
Jan 28, 2008 | Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
349 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
