Starts just fine but extremely high idle. wont change even while in drive or reverse. the truck has a Holley carb on it. seems to be still drivable
SOURCE: high idle speed on 1987 ford F150
it may be this or the ( pcv valve ) pcv get clogged alot on old fords.The idle air control valve (IAC) control the engine idle speed and dashpot functions. The valve is located on the throttlebody . This valve allows air to bypass the throttle plate. The amount of air is determined by the Powertrain Control Module (PCM) and controlled by a duty cycle signal.
TESTING
Due to the diode in the solenoid, place the ohmmeter positive lead on the VPWR pin and the negative lead on the ISC pin.
SOURCE: strong order of gas fumes and black residue on spark plugs
The jets in the carb are too big for a 302 with a stock cam. Take it to a carb shop and have them replace the jets with stock jets. (Or DIY and hope). Whne you converted from FI to carb did you replace fuel pump to get correct 7 1/2 psi pressure at carb inlet? FI pumps put out 50+ psi and a regulator maintians pressure at the injectors on the order of 35 psi.. Of course, that much pressure would force inlet needle valve out of it's seat and would probably flood carb totally, but, check the fuel pressure at the carb just to be sure. Good luck. 302's rule!!!!
PS - Check cam specs - FI engine has different cam - intake duration is longer if I remember correctly. Been a while since I got inside an engine...
SOURCE: Gas engine starts then stalls
The shop should have adjusted your air/fuel mixture on the carb. considering the year of the vehicle, you may need to replace the carb with a factory re-manufactured unit. Even if you replace the carb with a re-man, it will still need to be adjusted to optimum performance for your particular vehicle.
