Question about HP Color LaserJet 2600n Printer
Laser jet 2600n
I just bought 2 new cartidges and I can't get the white roller on the right side to go in so that I can put these new cartridges into the machine.
    Champion:
  • 220 Answers
Cartridge lock broken or has come of.pain of a thing to open and reseat.
Posted on Jun 19, 2009
  • Reg Chandra Jun 22, 2009
    Cartridge lock broken possibly.
I have hp color laser jet 2600n printer.. but after printing, there have line at the both side left and right on my paper.. the line is about 1cm .. how do i fix the problem.. tq..
If the lines are predominatly one color such as yellow or cyan then you likely have a bad cartridge. If you recently replaced a cartridge that is the one I would check first. You can also just look at the drum of each cartridge (the green roller under the shutter). If there is a problem it will usually show on the drum as well. Cartridges are the biggest issue with these printers, particularily the poor quality of cheap remanufactured cartridges coming from Asia.
Mar 16, 2011 | HP Color LaserJet 2600n Printer
My color Jaser jet 2600n does not recognize the new yellow print cartridge. I have tried two and they are right out of the box
If they are not genuine HP cartridges, they may be and are likely defective.....even two of them. I have seen it a millon times. Try putting the old one back in and see if the problem persists if it does not they are defective cartridges. Replace with genuine HP cartridge.
Jan 10, 2011 | HP Color LaserJet 2600n Printer
HP Business Ink-jet 1200 1) when it starts printing and the paper feeds it makes an extremely loud clunk sound regardless of the paper tray being used. 2) each and every time the paper comes through it...
The pickup roller is problematic. First clean, then replace if necessary.
The part should be under $20.
To replace (from HP Support):
1. Unplug the power cord from the
printer, and allow the printer to cool.
2. Open the toner cartridge door, and
remove the toner cartridge.
3. Locate the pickup roller.
4. Release the small, white tabs on
each side of the pickup roller by
pushing them away from the roller,
and then rotate the pickup roller
toward the front.
5. Gently pull the pickup roller up and
out.
6. Position the new pickup roller in the
slot of the previous pickup roller.
Note Circular and rectangular pegs on each
side prevent you from incorrectly
positioning the pickup roller.
7. Rotate the top of the new pickup
roller into position until the white
tabs on each side of the roller snap
the roller into place.
8. Reinstall the toner cartridge, and
close the toner cartridge door.
9. Plug the printer in to turn it back on.
Hope this helps.
Aug 16, 2009 | HP Business Inkjet 1000 - Printer - colour...
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Replacing paper pickup roller
on both sides of pickup rollers there are white bushings rotate the white bushings towards you
Remove the left-side bushing by sliding the bushing to the left.
Slide the roller and shaft toward the left until they clear the hole in the right-side bushing, and
then lift the right end of the shaft.
Slide the roller and shaft toward the right and lift the roller and shaft together out of the printer.
install your new roller then reverse this process to reinstall
Oct 21, 2008 | HP LaserJet 2430n Printer
Cant remove the hp 2600 cartridge from machine
hi
i have the same problem, but i can´t fix it, i just get in a PLANE screwdriver onto the rigth side of the cartridge RETENEDOR and push the white piece to the rigth and at the same time push up too.. and after a few times, you can release the cartidges easily
I hope to i can help you, sorry but my english is too bad jeje
Regards from venezuela
Sep 30, 2008 | HP Color LaserJet 2600n Printer
Laser jet 2600n
On the contrary, the 2600N does have a way to override. Press the check button and the right arrow button in this combination:
check, arrow, check, arrow, arrow, check, arrow, check, arrow, check, check.
This should bring you back to the ready screen after a brief pause. This will engage "Override Out". Repeat the check arrow steps in the same sequence to put it back to "Stop Out".
Jerry
Sep 08, 2008 | HP Color LaserJet 2600n Printer
Toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Feb 28, 2008 | HP LaserJet 1320 Printer
HP Color LaserJet 2600n Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
