Question about Microsoft Windows XP Professional SP2
Closing of command promt
When i start my comp this error message flashes."cmd encountered a problem and need to close".what should i do???
  • kn_adarsh
    kn_adarsh Jun 01, 2009
    i just completely formatted my system and it was smooth.but after some time ie after i copied some data only it started
    Guru:
  • 597 Answers
I would be worried about that started the cmd command. That is the command to open the old style DOS window. Usually some updates or installation programs might use the cmd window but might also be used by virus and malware installation. Does this happen every time you start the computer or just once? If it is an every time thing you need to check your start up directory and run "msconfig" to locate the program that is causing this. It would be wise to get a professional to help you. But first thing to do is reboot and run a virus scan.
Posted on Jun 01, 2009
  • obwhon Jun 01, 2009
    I've heard something about a cmd virus this morning. What I would recommend is
    You should try an online scan like Microsoft's http://www.microsoft.com/protect/product...
    If it finds a virus you can download repairs for just that virus from places like http://www.symantec.com/business/securit... Once you get the virus out your software may work.
    Good things on the internet don't cost money. Go download and install Spybot S&D. It's great for spyware and malware because it puts a list of the bad places in your restricted site zones so there's no way you get spybots and malware from them. Then go download and install anti-virus software from http://www.avg.com
    Sergeant:
    Champion:
  • 223 Answers
You may need to have the hard drive wiped clean and have Windows reinstalled.
Turned hibernation on in error .how do i turn it off again
You can turn it off under power management in control pannel. To avoid this issue in the future try this:
To make hibernation unavailable, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
  3. When you are prompted by User Account Control, click Continue.
  4. At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
  5. Type exit and then press ENTER to close the Command Prompt window.
To make hibernation available, follow these steps:
  4. At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Jul 21, 2011 | Toshiba Satellite L670DST2N01 Laptop
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
Svchost.com has encountered a problem and needs to close. We are sorry for the inconvenience.Why is that apeare when I whant to acesse un progaram.
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. also after this u have to clean ur registry using registry cleaner reg in out
Sep 17, 2010 | ASUS Eee PC 900 Notebook
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
I am using win 7. Trying to install Microsoft Office Home and Student 2007. Receive message encountered error during setup. Error 25004.Config.Xml not specfied; a valid config.Xml file must be authorized...
This problem occurs if the previous install was unsuccessful or re installation. Follow these steps to resolve this issue:
  1. Pres Windows logo key + R. The following dialogue should open:b1011b9.jpg
  2. Type cmd as shown and press enter. Command prompt will open:9efcac2.jpg
  3. Type cd %allusersprofile%\Application Data\Microsoft Help, and then press ENTER; type EXACTLY as shown: cfda63e.jpg
  4. Type attrib -h rgstrtn.lck, and then press ENTER.
  5. Type del rgstrtn.lck, and then press ENTER.
  6. Type exit, and then press ENTER.
Note: You must have Administrator privileges or you cannot follow the above steps. Also the test you are directed to type in command promt must be EXACT or it will not work (note the spaces between commands).
After successfully completing the above with no errors, try installing Office again.
For your convenience, the Windows logo key is found as:
Mar 07, 2010 | Computers & Internet
WMI Has encountered a problem and needs to close
Symptom
When you attempt to start the Windows Management Instrumentation (WMI) service, you may receive the following error message, and the service does not start:
Could not start the windows management instrumentation service on local computer.
Error 1068: The dependency service or group failed to start
Resolution
First, verify the number of dependencies attached to the WMI service. This can be viewed by running the following command from Start, Run:
CMD /K SC QC WINMGMT
The output should exactly as given below.
[SC] GetServiceConfig SUCCESS
SERVICE_NAME: winmgmt
TYPE : 20 WIN32_SHARE_PROCESS
START_TYPE : 2 AUTO_START
ERROR_CONTROL : 0 IGNORE
BINARY_PATH_NAME : C:\WINDOWS\system32\svchost.exe -k netsvcs
LOAD_ORDER_GROUP :
TAG : 0
DISPLAY_NAME : Windows Management Instrumentation
DEPENDENCIES : RPCSS
SERVICE_START_NAME : LocalSystem
*See attachment*
The only dependency is the RPCSS service, and it does run by default whenever you start Windows. If you have any other dependencies listed, then it may be the causing the problem. To remove the additional Dependencies, follow this:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Before you modify the registry, backup the registry key by exporting the corresponding branch. Also, see here to learn how to perform a complete registry backup.
Click Start, Run and type Regedit.exe
Navigate to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\winmgmt
Double-click DependOnService, and set it's Value data to RPCSS
Close Regedit and restart Windows
If this fails, you will need to do a repair installation..
Hope this will be helpfull
Thanks & Regards
NANDU
Mar 06, 2009 | Microsoft Windows XP Home Edition
Yahoo Messenger has encountered a problem and needs to close
it sounds like you have a corrupted operating system or an infection, make sure you download your windows updates, do a full virus scan with counterspy from www.counterspy.com download www.ccleaner.com make sure it's ccleaner, also re download messenger from http://messenger.yahoo.com the current version should be 9.0.0.2112 if that doesn't help hold windows key then push r type in chkdsk c:/f/r on xp, if vista type cmd into the search bar right click it and run as administrator then type chkdsk c:/f/r that will fix the corruption on your hard drive for the most part. you'll probably still need to re download messenger again.
Jan 17, 2009 | Yahoo Messenger
Messenger Error 80072745
This is sometimes caused by the cache left on Internet Explorer. If your internet's working fine, then follow these steps.
Close MSN Messenger
Open Internet Explorer. Set it to work offline (File > Work Offline)
Close Internet Explorer and reopen it. Now set it to work online (File > Work Offline).
Open Command Prompt (Start > Run > type "cmd" and hit enter)
Type "ipconfig /flushdns". You should recieve a message that your DNS has been successfully flushed.
You should now be able to connect to MSN Messenger. Open MSN and see if the problem is fixed.
Oct 19, 2008 | Microsoft Windows Live Messanger
Attempting to defrag drive C on a Compaq laptop, but receiving message. ANALYZER says must run chkdsc:/f There IS no f drive. How do I defrag this bugger?
that is not a f drive. follow this
start-run-cmd hit enter then cmd screen write the following command without quotes "chkdsk/f" hit enter then it will ask for yes or no you give yes and close the program and restart, the system will check for hard drive error then you try to defragmentation
Jul 28, 2008 | Computers & Internet
Microsoft Windows XP Professional SP2 Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
