Question about Haier HWD1000
E 31 error message on Haier HW1000
After running the HWD1000 for about a minute, it stops and gives an E31 message. I call the company and they suggested unplugging it, pushing each button on the control panel for 3 seconds. This didn't solve the problem. The unit ran well until the warrenty ran out (of course). Any ideas I bought my machine in May 2008 and after about 3 month started getting the E31 error during the rinse cycle. I called Haier and they sent a technician as it was still under warranty. The technician couldnt fix the problem so Haier sent me a new machine.. now 8 months later, I am having the getting the same error message during the rinse cycle. And of course this happens just as the warranty expires..
  • aneudy
    aneudy Mar 17, 2014
    I just fix the error, I searched the internet and say, engine problem, I found no more nothing, then slept on the floor the machine and check the wire to remove the plug from the engine I could see that the contacts were sulfated (oxidized) and the clean and the machine was working well, but as the contacts were very rusty preferred cut the first 3 wires (red, black and yellow) were those oxidized and the draw (union) direct, to make sure that in the future no further rusting again, in my case it solved the problem, I hope for your case too ...
  • 22 Answers
E31 Motor
The feedback signal does not change in 8 minutes during the motor runs <-- Bad translation that probably means bad sensor or electronics issue.
Call repair people and then get a new machine sent if still under warranty.
Posted on Aug 20, 2010
Posted on Mar 17, 2014
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
  • 41 Answers
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
Posted on Sep 03, 2009
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Posted on Feb 04, 2012
The dryer stopped working for my hwd1000 --
Check your belt. It may be shot. And that will cause your machine to do that. The heat will still work but your clothes will not dry.
Jun 14, 2017 | Haier HWD1000
My washing is saying error 2
E11 is low water pressure
E12 is a slow drainage problem
E13 too much water
E31 motor problems
U02 is cannot lock the door after 20 seconds
E22 is memory failure
what exactly does the error message come up with and when does it occur
Feb 24, 2011 | Haier HWD1000
I set it to dry for 1 hour but after 30 minutes it stops, what's wrong with this?
It sounds like the thermostat is overheating, Clean the filters, and make sure there is plenty of air flowing freely around the machine while it is running.
Feb 20, 2011 | Haier HWD1000
Error 4 ON HAIER WASHING MACHINE.
Error U04 means the door is open.
Put your knee against the door handle and press it against the handle until you hear a click. The machine should start filling within a minute.
This is a problem I had start occurring about a month after I started using the machine. You will soon do this for every load, a minor annoyance on a cheap machine.
Error EC4 refers to the temperature of the air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
Ask the technician to
repair it.
Alternatively make a custom cycle with no drying cycle and hang dry the laundry. I usually do this myself as opposed to listening to it groan for 2-3 hours.
Aug 10, 2010 | Haier HWD1000
On my Haier HWD1000, I keep getting error message E11... what does this mean?
Error E11 means either:
The water level can not
reach the reset water level
within 5 minutes
OR
reach the setting water level
within 8 minutes
What this means is check your water supply for sufficient pressure and if for some reason it stops and starts (eg. well drawn water with a small reservoir sometimes.)
You may have to make sure that there are no other water uses going on at the same time.
Jun 21, 2010 | Haier HWD1000
My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
Jun 11, 2009 | Haier HWD1000
Jan 31, 2009 | Haier HWD1000
Dryer Problem
EC4 The temperature of air vent
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
Haier HWD1000 Logo
1,272 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
