Question about EnGenius EOC-3220 (EOC3220)
How to make my own wifi antenna splitter?
I just want to learn how to make my own wifi antenna splitter by two ways. Anyone knows? Please help me..Thanks in advance.
  • Cheater Cheater Oct 24, 2007
    Hi Benimur,
    Thank you very much for alway's given me a chance to answer all my problem. Actually, I wan't my WIFI radio uses two antenna. I was already tried but I used to connect the other antenna with the previous one which the signal goes to the last antenna I installed. Probably, I need one component to split the signal into two antenna.
    Hoping that you still interested to help me.
    Best regards,
    Philip
    Brigadier General:
  • 6,966 Answers
Philip,
If you are planning to use a single antenna and then use a "splitter" to connect two (2) WiFi units, I'm afraid that it will not work.
Antenna splitters are meant for receive only mode but since WiFi operates both on receive and transmit, then perhaps what you would need is a "duplexer".
Both of your WiFis would be operating on 2.4GHz band.  Theoretically, you would have to fix set your first WiFi device to operate on the lowest channel possible and the other on the highest channel possible. The channel separation translates to frequency difference; lowest for Channel 1 is 2.401GHz while the highest for Channel 11 is 2.473GHz.
Constructing your own would be at best a daunting task since you would need to be very familiar with electronic components and circuitry in the microwave region. Further, you have to have access to specialized equipment (microwave capable) such as a spectrum analyzer, swr meter, dummy loaded wattmeter and a frequency counter to say the least.  In most countries, you would also need certain licenses to do this.
With all of these in mind, your best bet might be to use individual external antennas for each WiFi device and positioned them as far away as possible from each other.  Moreover, pls bear in mind that anything between the transmitter and the antenna would introduce attenuation, insertion and return loss and this include even just the cable.
If you would still want to give it a try:
  1. Here is a   link  to  commercial duplexer for  amateur radio;
  2. Here’s a   link  to  a do-it-yourself page for lower amateur frequencies;
  3. This is a   link   to a component supplier page.
Good luck and kind regards.
Posted on Oct 24, 2007
  • Louie  Role
    Louie Role Oct 24, 2007
    HI again Philip,
    Appreciate the quick rating.
    Re your problem, can you pls post it as a new problem but specify what type or units will be attached to the splitter, what will be the operating frequencies or band and what antenna will be used.
  • Louie  Role
    P.S.
    Would you also rate my solution to your initial post, re the radio problem pls?
    and thanks too.
Can you hook two tvs into one antena
yes --
got to places like Jaycar and get an antenna splitter
antenna shops will have it as well
does not have to be expensive unless you want more than 2 extra tv sets and then the internal circuit gets a bit more complicated
check the end of your antenna as they can be screw on or push on
Dec 31, 2016 | Televison & Video
How to use my Cnet CWR-854 Router as a wirerless antenna for pc.
You can't really use a router to connect to another router, you can sometimes use them as an "Extender" for range, but not as a WiFi card, they simply aren't made to operate that way.
Feb 19, 2010 | Computers & Internet
Vizio l37 When I try to scan the channels automatically the TV can find all the ones that comes from the comcast cable (62) but when stars to scan the digital ones freeze make me cancel the process and...
you cann not hook an antenna and cable to a splitter together and expect it to work
the only way that will work , if your tv had two tunners Try doing a scan with cable
only on the cable setting
Nov 03, 2009 | Vizio L37 Television
Can anyone help me locate the internal wifi antenna of my travel 2428
You will need to have the laptop taken apart to be sure. Most manufacturers wrap the wireless antenna around the monitor. The only way to be sure is to find someone who has worked your model, or follow the the antenna from the wireless card inside your notebook
Jun 16, 2009 | Acer TravelMate 2424WXMi_S58 PC Notebook
Tiling on HDTV
FIXED MY TILING PROBLEM-FINALLY !!!!
After months and months of freezing pictures and audio drop outs, I took it upon myself to see if I could fiquire this out.
In the attic I located my main cable feed was connecting to a 5-way splitter. That means my signal is being split 5 different time to go to 5 different TV jacks.
FIRST, I disconnected the main cable line from the 5-way splitter and connected it to a 2-way splitter.
SECOND, I connected the line that goes to my main TV (cable box) to the 2-way splitter.
THIRD, I connected a cable from the 2-way splitter back to the 5-way splitter.
THAT'S IT !!!!
My other TVs which don't use a cable box, never had any tiling issues, just the HDTV with the cable box. So now the signal to the HDTV is only split twice instead of 5 times.
Mark Matherne
Apr 01, 2009 | Televison & Video
No antenna cables on toshiba satellite 1405 s151
Some models that come with a wifi card already in them have an antenna. Since you purchased your card after the laptop it does not have an internal antenna. You can purchase the internal antenna but this will require you to take apart your screen.
You could purchase a PCMCIA or USB wifi adapter and use an antenna with those devices without taking apart your laptop.
Hope this helps.
Jei
Dec 12, 2008 | Toshiba Satellite 1405-S151 Notebook
How do i install a 3 way antenna splitter
If you want to install it 'in line' you need to cut the coaxial cable,then instal a jack plug on each end, connect these to the in' and out terminals then connect your third cable to the other out terminal.
Please remember to rate this solution.
Dec 07, 2008 | Leviton Antenna splitter
I have Rabbit Ears on an analog TV using a Zenith digital converter box. But how do I tape a TV show on my VCR that I'm not watching? I purchased another digital converter box to attach to the VCR but what...
The only way you can tape a different show than you're watching is to do as you have done: purchase a second converter box and connect it to the VCR as you did with the TV. You can pick up a device called a splitter which will allow you to divide the antenna signal between the two boxes.
There are some problems with the splitter arrangement. If you need to adjust the antenna position to get a good signal on one channel, like the one you want to watch, that may mean it isn't in the best position for another, like the one you want to record. You might need two antennas for the best performance.
Also, you can't program recording on different channels at different times unless you'll be home to change channels on the converter box. The VCR will only find a signal on channel 3 or 4, depending on how you set up the box, and you'll always record on that channel. The TV channel you record will be chosen by the converter.
Finally, you need to connect both the VCR and the converter box to a single antenna connection on your TV. There are two ways to do this. One is to use a splitter again. Normally they are used to split a single antenna input to two ouputs, but they can also combine to inputs into one output (basically you just use it backwards). Connect the ouputs from the box and VCR to the splitter's output connectors, and then go from the splitter's input connector to the TV antenna connector. This arrangement may not give the best picture quality, though. An alternative is to use an "A/B" switch, which allows you to choose which source connects to the TV.
It sounds more complicated to hook up than it actually is. It is more complicated and less flexible to use this setup than it was before the switch to digital broadcasting, but they call this "progress."
Hope this helps. If you need more information, just post a followup comment!
Nov 29, 2008 | Insignia Digital-to-Analog Converter for...
360 degree outdoor antenna radio shack
What type of antenna is this. You will need 75ohm cable for this with good 75 ohm 3 way splitter. Please be sure that TV cable is not going to work.
May 22, 2008 | Radio Shack Audio Players & Recorders
EnGenius EOC-3220 (EOC3220) Logo
3,592 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
jgbyers1
Level 1 Expert
Tech support
Tech support
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
