I have a Craftsman 14" band saw, Model 124.32607. The drive belt won't stay on. Any ideas?
SOURCE: manual craftsman band saw
I just went to Sears.com and then to Sears Parts Direct (down at the bottom of page under Craftsman tools) and typed in your model number. You can look at this manual online. Good luck
SOURCE: I have a craftsman band
Go to SEARS PARTS DIRECT.COM and type in your model number and you can view a manual or get one.
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there. If the back guide is a roller bearing I woud think you would want to roll all of the time. If a solid bearing block natually a small space where it will not hit is enough.
SOURCE: I have a 12 inch Sears/Craftsman band saw. I got
that is where I would look first, you would need your model number and go to Searspartsdirect.com and type in your model number to find and order the replacement rubber tires and that should take care of your problem
SOURCE: Broken drive belt on ryobi band saw, need
Just go to a well equipped hardware or auto parts store. Take the old belt with you so they can find an exact replacement. Good luck!
