Question about Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966
Never used trimmer won't stay running.
My son purchased this trimmer a few years ago and never got it running. I took it and while I can get it to start, although not easily, it runs only for a minute or so and then stops. I have checked the plug and spark arrestor, put in fresh oil and gas and still no luck. I have gone through the starting process numerous times and still the same results. I have pulled the cord so many times my fingers are black and blue. It seems as if the gas is not continuing to get to the combustion cylinder. Determined to get it running but can not find any DIY guides on-line. What are the next steps I should take to get this in running order?
  • 323 Answers
Sometimes when they set up a long time the gas turns to something that smells like shellac and clogs up the fuel lines and the carb jets. Even though you've put in fresh gas, (1:50 ratio) the carb and lines may still be gunky. If you get it to start by spraying starter fluid in the carb, then its simply running out the starter fluid.
I would begin by replacing all the little plastic hoses from the gas tank to the carb and make sure the primer bulb is in good condition. That done, I'd take off the air filter and spray carb cleaner through it until it ran out. You'll have to crank some, without expecting it to start, but you have to get whatever is in there out.
This will mess up the spark plug, so if you have the old one, put it back in until the cleaning is done.
Press the primer bulb until you know fresh gas is coming out. When it is thoroughly cleaned, put it all back together and let it dry out.
Then try again, giving the bulb 4 or 5 hits. If it turns over on full choke and sounds as though it might run, back off the choke a little. You'll probably need to spray starter fluid in the carb until it is drawing fresh gas.
If you can't get it to run continuously, get a small screwdriver and when you get ready to start, turn the high speed adjustment a 1/4th turn to the right.
Keep trying that until it either runs or doesn't. Keep track of how many quarter turns you make. When it does start, hold the throttle wide open. If you've turned the screw to a point where it won't start at all, turn the hi speed screw back the number of turns you opened it, and then turn it all the way closed, counting the number of turns from where it originally was. After closing it, try a starting point at about 2.5 turns open. Once you get it started at wide open throttle, you have to play with the high speed screw, turning it first open, listening to the sound of the engine. If it starts to sound smoother, continue until it starts to stutter, then go back 1/2 turn. If it doesn't start, or sounds worse when you open it, turn back closed until it smooths out. Once started and it keeps running, run it long enough to get everything burned out.
To get it started easily after the hi speed is ok, then play with the low speed the same way. I would start by closing it (left) and counting the turns. Then go back to that point and open 1/2 turn. Do that until it either starts easily or is obvious it won't start and run well at low speed. Then go the other way.
It takes a while, but it will be worth it once you get it running. If all else fails, you can buy a new carb online for probably $30.
Good Luck!
Sirwriter
Posted on Jun 01, 2009
    Sergeant:
    Champion:
  • 223 Answers
Check the gas line and the return. The hoses may be clogged or defective.
2 cycle 30 cc homelite will start but not stay running
I had one of these a few years ago which started doing the same thing. I get fed up with it, and was going to throw it away. I gave it to a friend who found the fuel system was partially blocked. After running some carby cleaner through it, it worked fine. Its still going now...
Aug 18, 2014 | Homelite Consumer Products Tiller...
My trimmer will start for a few seconds running only from the primer blub but will not continue to run from the main gas line. I can see that it is not drawing gas from the main gas line.
take the carb off then pull it apart and thoroughly clean every hole and part with carb cleaner, make shure you you clean the neddle valve and there is no biuld up on the floats. also mak sure there isn't any holes in the floats an in the diafram
Apr 21, 2013 | Garden
Homelite weedeater mod. 26cs
Try going to ebay and finding a carb for the model, some are as cheap as $12.
Mar 12, 2017 | Homelite Mighty Lite Lawn Trimmer
Hello, I have a Echo PE-200 that won't stay
You definitely have carb. problems. The fuel probably varnisized. In this case, you may have to place the carburetor in carb. dip for a few hours.
Try my Tip out:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Aug 05, 2011 | Echo Garden
Line wont stay in.
I have one like this also. The retaining nut (ring) for the stringhead is inadequate as are some of the other parts on this budget priced unit, If you wanna use it I would suggest puttting a different type of string-head on it if you can.
Jun 07, 2010 | Garden
Difficulty staying running need to apply choke.
Normally when you have to apply the choke on a machine it means that the carb has trash in it, or the diaphragms a getting hard and not functioning as they should.
Time to rebuild the carb on your trimmer if your trimmer is a few years old, otherwise take apart the carb and blow all passages out with compressed air, clean all surfaces and reassemble and install on the machine.
Good Luck,
I hope this helped, Please rate me
Apr 08, 2010 | Garden
I have a stihl fs76 weed trimmer. It will start but not stay running. I took the carb apart cleaned it. It looks fine but it still won`t run good. Any common problems or ideas ?
Hi..my name is Keith...it sounds like the reeds in your carb needs replacing...usually if you use a carberator cleaner on them..it will ruin them..plus age will make them stiff..they should be as soft a rose petal..and its cheap and inexpensive to replace..but you have to pay attention to how many layers and the shape of the reeds that come out..because the kit that you buy will fix several different carbs..i hope this has helped..if not..write back
Jul 01, 2009 | Garden
Weed Eater GTI 15 won't run???
Check the gas lines, one might be bad...
Jun 01, 2009 | Garden
Troy Bilt 17 Inch 29 Cc Gas Powered Clutched Curve Shaft Trimmer #41ADT52C966 Logo
230 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
