Question about Kenmore Dryers
It wont dry my clothes
Everything works on my dryer but it wont dry my clothes and doesnt get hot.
  • 6,784 Answers
Check the following for a gas dryer--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Check the following for a electric dryer--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Posted on Jun 01, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
We have an lg dle3777w dryer and it doesnt seem to get very hot to dry the clothing...it takes many cycles to get one load dry...any ideas???
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG DLE3777 Electric Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Clothes wont dry but gets really hot
make sure your exhaust line is clear and not kinked
Oct 24, 2008 | Washing Machines
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
168 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
