Question about Disney Ice Cream Maker
Not setting / freezing - bowl in freezer 24 hours *
Not setting / freezing - ingrdients remain liquid - bowl in freezer over 24 hours
    President:
  • 3,433 Answers
The ice cream mix has to be xconstantly stir in a nrine solution, That's why they have motorized ice cream makers that rotate the can surrounded by ice and salt.(brine) while a paddle inside stirs it. Good luck and enjoy.
Posted on Jun 02, 2009
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: My freezer bowl not freezing
Thaw the bowl and re-place it in the freezer - make sure it is sitting perfectly level. Don't remove the freezer bowl until you are immediately ready to pour in the ingredients - letting it sit out for even 5 minutes will be too long, as it thaws quickly.
Posted on Mar 20, 2009
How long to freeze bucket
Homemade Ice Cream Freezing Methods - RecipeTips.com
www.recipetips.com/...tips/.../homemade-ice-cream-freezing-methods.as...
Rating: 5 - ‎2 votes
Jump to Ice Cream Maker Using Ice - This type of freezing process is known as a "stir ... Place the covered ice cream can in the bucket, making sure it is ...
equipment - How long do I need to freeze the freezer bowl ...
cooking.stackexchange.com/.../how-long-do-i-need-to-freeze-the-freezer...
Dec 30, 2010 - Is a couple of hours in the freezer enough, or do I need to wait until tomorrow morning? ... This really depends on your freezer and your icecream bowl. Usually ... How to clean ice from ice cream maker bowl without thawing?
[PDF]Frozen Yogurt-Ice Cream & Sorbet Maker - Cuisinart
Jan 14, 2016 | Ice Cream Makers
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice cream not firm
The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
-Tha Mp3 Doctor
Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Put the ice cream bowl in the dishwasher
The only way to tell is by putting it in the freezer for 24 hours, and then trying to make a batch of ice cream. If it doesn't freeze or make the ice cream properly, then you will need to get a replacement bowl from Cuisinart - they are available.
-Tha Mp3 Doctor
Aug 11, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
My freezer bowl not freezing anymore I let in the freezer more the 24 hours and it's still liquid
Jul 17, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Tank won't freeze
The keys are to make sure the freezer is cold enough, and to make sure the bowl is level when it is sitting in the freezer. 24 hours is usually required, despite what manual says.
If all else fails, the freezer bowls are replaceable - you can order them from Cuisinart - if you are in-warranty, they may even be able to give it to you for free.
-tha Mp3 Doctor
Jul 08, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Does not work
same problem. looking for solution(s). Got 3-4 good batches out of it, then it stopped properly freezing.
Mar 28, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    Disney Ice Cream Maker Logo
    448 people viewed this question
    Top Disney Ice Cream Makers Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Disney Ice Cream Maker Expert? Answer questions, earn points and help others
