Question about Hoover Dryers
Dryer blowing cold
I have a Hoover Nextra HNWL6136 washer dryer, the dryer no longer blows hot air but goes through the cycle fine. what would cause this?
Thanks Ian
  • 2 more comments
  • ian_cross Jun 09, 2009
    It is an electric dryer and doesnt dry the clothes at all. It blows cold air into the drum.
    It is an electric dryer and it does not dry the clothes at all. It is blowing cold air into the drum.
    Thanks Ian
  • Michael Masters
    Michael Masters May 11, 2010
    what type of dryer is this? electric or gas???
  • Michael Masters
    OK, is the dryer drying the clothes correctly or, it it not drying the clothes at all?
  • 6,784 Answers
Check the following to address this issue.
Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Please rate and have a great day:)
Posted on Jun 09, 2009
Hoover Nextra 7148 not drying
id check for fluff inside the machine casing.............blocking the air flow...........
cheers
Aug 30, 2017 | Hoover Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hoover nextra washer was showing fault code 3. on inspection i found a ten pence piece in the in hard plastic pipe of the pump. removed blockage and set it to cycle. machine was showing fault code 1. i...
Hoover Nextra fault code 1 actually decodes as 'door interlock/door switch' (???!!)
Fault code 2 states' fill time-out or solenoid valve etc'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 19, 2011 | Hoover Washing Machines
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer only blowing cold air, washing cycle fine.
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element washer motor has heat overload sensor
thumbs up
Aug 17, 2009 | Washing Machines
Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Jan 13, 2009 | Conia DVD8500 DVD Player
Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Oct 31, 2007 | Hoover Nextra 160 HNWF 3137 Front Load...
Dryers Logo
408 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
