Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer over fills and floods the floor
When the washer fills sometimes it will overfill and run onto the floor
  • 6,784 Answers
Morning. There is a Water fill level switch in your unit that monitors the level of the fill process. this switch is malfunctioning and, it will need to be replaced asap if possible.
Posted on Jun 01, 2009
The washer continues to fill until it flood out
Good Morning Friend,
I understand that your Frigidaire washer, model# ATF6000ES, continues to fill with water until it floods out. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. When power has been restored, select any cycle and start it. If your washer is still overfilling and flooding out, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to overfill and flood. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire ATF6000ES Front Load Washer
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
The washing machine will overflow, flooding water onto the floor. Flooding has happened 8 times, and it attempted to do it about another 5 times (I stand there and watch it and turn off the water supplies...
ive included a solution to a similar problem that i solved earlier this week, i hope you find this helpfull...
I am assuming this is a top load washing machine.... the load size selector button has a hose attached to the back of it. This hose goes down to an overflow box mounted to the side of the tub. This tube often gets clogged and the machine cannot tell where the water level is. 1) dissconnect the tube from the level selector switch and ( w/it unplugged ) attach another tube to it and blow into it. you should hear a clicking sound. this means your level selector switch is functioning properly. if it does not click then it needs to be replaced. 2) dissconnect the tube from the level selector switch and ( w/it unplugged ) blow into the tube and you should hear air going into the tub, ( this is best performed with water in the tub ( bubbles ) )....hope this helps
Asker's Testimonial " Thanks rdrsp. When I took the control panel off, I found that the tube had fallen off the control valve. I put it back on with a band clamp. " - bill_marv460 "
Oct 22, 2009 | GE WVSR1060A Top Load Washer
Water level will not stop and floods floor
check the level switch by blowing on it if clicks is good if not replace the switch , make sure that the hose that connects to the switch is free of debri
Jun 18, 2009 | Kenmore 22422 Top Load Washer
OVERFILLED AND FLOODED HOUSE
1 of two problems happened.
1) either the water level sensor went bad. Which tells the water inlet valve when to shut off and the machine to start operating.
2) The water inlet valve has failed. This comes from the water hose and fills the washing machine.
May 25, 2009 | General Electric WCSR2090D Top Load Washer
Hot water runs constantly - overfills
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to.
Jan 11, 2009 | LG WM-2277HW Front Load Washer
My maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
SMEG INTEGRATED DISHWASHER FLOODING
Are you saying it overfilled and flooded out, or did it empty onto the floor?
Nov 18, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
