Question about Boating
Split hull My pelican fishing boat has a couple of cracks in the hull I need to repair
  • 70 Answers
V out the cracks with a grinder, cut fiberglass matting with an overlap of about half an inch. pre-cut 6 more pieces gradually stepping overlap to 1 1/2 inch starting with smallest piece soak in resin and place over v'd out crack, once all pieces are in place press out any air bubbles. takes a while to dry. once dry sand flat with 36 grit then 80 and 150. place a gelcoat on top
Posted on Jun 22, 2009
  • paul baker
    paul baker Jun 22, 2009
    this is not a procedure for the novice
Boston whaler boat. fiberglass repair
fibre glass repair kits are readily available from quality hard ware shops , marine shops and boating supplies and e-bay
there are plenty of youtube pages showing how to do the job
But if you are still hesitant about doing the job yourself take the boat to a marine dealer or shipright and have the job done professionally
Jul 12, 2015 | Boating
Water in hull of bass tender pro
Find the leak and patch it. Use a good marine epoxy system with a sheet or two of fiberglass cloth laid-across the crack. Be sure to sandpaper the area thoroughly with rough paper. If you can't find a leak or crack, fill the hull with water and inspect for leak. Repair after.
May 20, 2014 | KL Industries Basstender 10.2 Fishing Boat
Guys I have a 2007 polar 23cc I am wanting to put a shoot through transducer on the hull. My question: has my boat got a solid or cored hull?
Go to
thehulltruth.com
and post your question and you will get a quick informed answer.
Happy boating, Pete
Sep 03, 2013 | Boating
I have two 4 ft cracks on my pelican pedal boat canit be repaired
If the boat is Fiberglass, it can be repaired with fiberglass Matt and resin.
Jun 17, 2012 | RTO Pelican Monaco Pedal Boat
I have two 4 ft cracks on the sides of my pelican pedal boat. Can it be repaired
What is the material?
Are the cracks along seams?
Are the cracks at stress points, from freezing in winter, or what?
Holes shot in hull how do i fix
hi is the hull made of fiberglass, if so you can normally buy these type of repair kits from car spares shops, they include fibre glass resin and sealer, good look.
Oct 30, 2010 | RTO Pelican Monaco Pedal Boat
Repair of small crack/cut in the hull bottom...3 " long..1/64" or less wide...
It depends on the material of the hull. If it is Fiberglass then buy a small auto or boat repair fibreglass kit and follow instructions in the kit.
. If it is one of the engineering thermoplastics like High density Polyethylene ABS or Polypropylene I would try and find somone who can weld it with the appropriate material. This would be done by carefully shaping the plastic away from the crack to form a "V" shaped recess and then filling the gap with the appropriate filler rod usually using a hot air blower designed for the job.
Jun 02, 2010 | RTO Pelican Monaco Pedal Boat
Can hear water in the hull; is there a quick drain and where is the most likely area it is leaking from, is there a kit? model H27.
in the nose of the boat right next to the handle theres a funny looking switch if you stand the boat on its nose and flip the switch it will let the water out.
But...in my personal opinion it keeps the hull a little lower to the water and the paddles deeper...
Feb 04, 2010 | RTO Pelican Monaco Pedal Boat
Boating Logo
116 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
