Question about Canon iR 2022i Printer
Scanning a legal size document
I am scanning documents from the top feeder. The top feeders default is to place the paper horizontaly which only fits letter. I need to scan a legal size document. When I place it in vertically half my page is cut off. I have tried to adjust the settings but am doing something wrong.
    President:
  • 1,126 Answers
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Posted on Jun 05, 2009
How do i scan a legal size document on hp officejet 6830
You will need to use the automatic document feeder and there should be an option in the scanner software settings to tell it you are scanning a legal document.
Jan 31, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
How do I scane on my mx310
You will need to plug the printer andcomputer together with a USB cable in order to use the printer's scanningcapabilities. The scanning unit on theMX310 features an automatic document feeder on top of the printer, which willscan multiple pages itself. You can also choose to load documents on thescanning glass, which is covered by the scanner's lid. This is how to do it. 1. Turn on the printer by pressingthe "Power" button until it illuminates and turn on the attachedcomputer. Wait for the printer to finish its initialization process beforecontinuing. 2. Place the document face up inthe automatic document feeder if the document's papers are uniform in andfit in the feed tray. Adjust the paper-width guide to the of thedocument's papers. 3. Place the first page of thedocument face down on the scanning glass after you have lifted the scanningunit's cover, if you choose to not use the automatic document feeder. Close thecover again slowly so the document does not shift on the glass. 4. Press the "Scan"button on the printer's control panel, then press either "Black" or"Color," depending on the type of scan you would like to perform. 5. Retrieve the scanned documentfrom the automatic document feeder's output tray once the scan job is over.Otherwise, click on the "Yes" button on the computer's screen,indicating you would like to scan another page. 6. Lift the scanning unit's cover,remove the document from the scanning glass and place the next page of thedocument face down on the glass. Close the scanner's cover and click on the"OK" button on the screen to scan the next page. Repeat this processuntil all of the document's pages have been scanned.
Jan 13, 2011 | Canon PIXMA MX310 All-In-One Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Will not scan from glass but feeder will?
Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
Steps
1. Click on Start, Programs, Paperport
2. Right above the Word "SCAN", you will have several options on;
a. Document or Photo
b. Flatbed or Feeder
3. Once step 2b has been selected, the M20i will scan your document per your instructions.
Note:#1
If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
Note #2
Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
I hope this resolves the confusion between GLASS and FEEDER scanning.
Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Not scanning full page
You omitted some details which might help diagnose the problem. For example, are you using the document feeder or the flatbed? Anyway, I'll take a guess here.
Check your paper size setting and make sure it matches the sheet you are scanning. (Letter, A4, Legal, etc.)
If this is not it, then try scanning from both flatbed and feeder and see if results vary. Note that when you use the feeder, scanning is done in a smaller window to the left of the flatbed, so make sure that is clean.
Mar 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
I can't Scan 8 1/2 by 14. It cuts the scan to that of a regular paper. I can fax by 8 1/2 by 14 and it comes out alright. how i do the set up. I used the set up in the scan but it did not help.
I also had problems scanning legal size documents with a Brother MFC-7440N. The documents would scan but would not come out complete. A large portion of the text would always be left out and only an image of the size of regular page size would come out. I knew it had to be something with the settings, so after experimenting with my MFC-7440N I came to the conclusion that I was not going to find the solution on the actual machine. I had a "Hunch" that I would find my solution by connecting the printer to my laptop computer and use the software that came with it. After a couple of minutes I was able to scan Legal Size documents in a breeze... I should of done this months ago. All scanned docs came out in full size.
So I took some screen shots to post them up here to let everyone know how to scan legal size documents since I noticed that people are having trouble just like I did. With this instructions you will also be able to scan any available size documents with a Brother MFC-7440N. I will also guide you step by step. After step 4 the remainder steps are OPTIONAL unless you need to change the color or picture file types. Okay, here we go!
Step 1.
Make sure your MFC-7440N is connected to your computer and the computer has the software installed that came with the printer.
Place the Legal Sized documents/papers that you want to scan on the Paper Feeder Scanner located on the most upper area of the machine.
Step 2. On your computer, go to START then to DEVICES and PRINTERS, or CONTROL PANEL then DEVICES and PRINTERS. Locate the icon of your MFC-7440N. If its not your DEFAULT printer make it the default one. Then RIGHT Click on the icon. A menu will pop open. Locate START SCAN and click it.
Step 3. A small window will open that will give you various options to scan a multitude of sizes and different settings. Locate where it says SOURCE. The default setting might be FLATBED meaning the flatbed scanner of your machine. Click the drop down menu and select FEEDER. By selecting the feeder option your computer will tell your machine to use the automatic paper scanner located on the most upper area of your machine.
Step 4. Locate PAPER SIZE. Click on the drop down menu and then select Legal 8.5 x 14 inches (216 x 356mm).
If your documents are already located in the feeder you can now go ahead and click SCAN and your documents will begin to scan.
Your scanned documents will be saved in a file folder in your computer and that file will pop open for your convenience once all documents are scanned.
If you need to change COLOR or Black and White setting plus Picture File Types such as Jpeg or Tiff just click on their respective drop down menu before clicking SCAN.Here are some pictures to help me illustrate it.
I hope you find this helpful.
Thank You!
Visit me at:
Facebook.com/BestCreditRepairManualor at
BestCreditRepairManual.com 92c85b21-a89d-4f9a-bf67-a96f103f2c15.jpeg 6adfe3bc-45ef-4e80-a6b2-7b825e659868.jpeg da5aa6de-6531-4fb6-9f91-3a1b503ac89c.jpeg 36e97075-1229-4d28-b14c-e7371ad26589.jpeg 15d2f41b-30e0-42cd-9e6d-663e9bb17a3c.jpeg 6d240b8f-2360-4094-8d6b-0c8cd404332c.jpeg 4203c1e5-8b35-4dc9-a802-65652251f028.jpeg
Oct 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Canon iR 2022i Printer Logo
288 people viewed this question
old marine
old marine
