After clearing a paper jam, I put the paper tray back in and when the printer resets, I get a grinding of gears on the left side. I thought I had to do with damage to my toner/drum, so I replaced both with new units and when I turn it on, the same grinding noise. It sounds like it is trying to cycle through but gears are stuck? I am having the same problem, I read through other troubleshooting solutions and tried not only unplugging the device but unplugging the USB cord also, when I do that and turn it back on, the status light is green and the drum light flashes. Then once I try to print the grinding noise starts, nothing prints and the status light turns red and the paper light flashes. So I don't know if I'm having trouble with the drum, or something else. There is no paper stuck I have taken apart everything I can and checked and cleaned everything!
cannot change the rollers in a Brothers HL-5250DN due to crinkling papers as it prints... How do I...
(More)
cannot change the rollers in a Brothers HL-5250DN due to crinkling papers as it prints... How do I do this?
my printer wont properly feed the paper through -- keeps saying no paper bt the tray is full of...
(More)
my printer wont properly feed the paper through -- keeps saying no paper bt the tray is full of paper
We have a HL 2070N Brother printer that the toner light will no go off. We have tried new cartridge,...
(More)
We have a HL 2070N Brother printer that the toner light will no go off. We have tried new cartridge, powering off, opening the front and back doors while holding the GO button. What's the best way to reset toner light.
I changed my HL-5250DN from local USB to Ethernet on my DI-604 router. I cannot print from...
(More)
I changed my HL-5250DN from local USB to Ethernet on my DI-604 router. I cannot print from Wordperfect X4, SP2. I receive this msg. "The document page is set to a paper size (letter) that is not supported by thid printer driver. Do you want to match to the closest printer defined paper size (Organizer M)?" I have reloaded Word perfect and the drivers from the Printer CD. Each made no change. I can print from any text editor and from MS Word 2003. Can you help me please? Thank you Jamie Jamieson 1woodshaper2@gmail.com
