Question about Maytag Dryers
Does not completely dry clothes in the time it used to
Clothes still damp when drying time is done, vent is clear no blockage
  • 6,784 Answers
For Electric Dryers, check the following---
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
For Gas Dryer, Check the following---
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
Posted on Jun 01, 2009
Why is my dryer damp in the morning after using it the night before
Hello. I need the model number to really help you accurately. However, this symptom is indicative of a possible blockage in the vent tube--either the flexible part connecting the dryer to the wall, or inside the wall, OR BOTH! Here's a relatively quick test. Remove the lint screen and any clothes from the dryer. Next, remove the vent hose from the bottom rear of the dryer. It can be sort of a pain to re-attach, especially if your laundry room is tight! Anyway, set the dryer for time-dry and turn it on--there should be a hard air-blow out the back of the dryer. Feel the pressure with your hand. Re-attach the hose and again, turn on the dryer. Go outside and locate the exhaust vent. You should feel a blow of air darn close to what you felt behind the dryer. IF YOU DON'T FEEL ANY AIRFLOW, OR IF IT'S SIGNIFICANTLY WEAKER, **YOU HAVE A BLOCKAGE SOMEWHERE IN THE AIR PATH**. This blockage is causing air movement in the dryer to be restricted--that air is full of moisture from the evaporated water out of the clothes. It has nowhere to go. Your clothes are probably taking a longer time to dry(if at all). You need to find and clear the blockage asap--the clock is ticking before you prematurely burn out the heating coil or pop a thermal safety fuse which prevents a fire. If you have a roof vent, it needs to be cleaned approximately every 4 months. If you have a long run through the walls or especially under the concrete slab, same rule applies. Lint turns into paper machet when it gets wet. It builds up like cholesterol in an artery and usually starts getting thicker towards the vent opening(cold air re-condenses the evaporated water). I hope I helped you!
Sep 05, 2015 | Whirlpool Dryers
Dryer takes too long to dry. GETS HOT...but not drying. Ran two cycles, frame work was hot, but clothes were not compelety dry. Note: not any lint either.??
make sure all the venting is clear of build up and debris,, clogged venting will not allow the moisture to escape the dryer resulting in damp and undry clothes ,, don't forget to check the outdorr vent and clear anything built up inside of that too
Jul 12, 2011 | Dryers
Does not dry clouse completly have to restart dry FDG648GFSO
Jul 12, 2011 | Frigidaire AGQ6000ES Gas Dryer
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore 90 series dryer leaves clothes damp. The dryer gets hot, but after almost 2 hours a large load is still damp. Happens on both auto sensing & timed dry. Checked insides & all is clear -...
Sounds like a venting problem at the house pipe.
Make sure the house venting pipe is completely clean and vent hood just outside is free of any blockages.
If all that is cleaned I would check all working thermostats and high limit thermostat as well.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
207 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
