Hi, My Washer stopped working,I would press the start button to start washing and nothing happened. I contacted the folks at www.RepairClinic.com and I ordered the main controller board and the motor speed control board, I replaced them and now when I press the START button I hear the clicks for the door lock, and several relays inside clicking but the washer doesn't do anything, it does not activate the water fill up and it never gets to spin... what could it be ? some sensor or relay or switch telling the computer not to do anything ?
  • 5 more comments
  • Luis Perez
    Luis Perez Jun 01, 2009
    yes thanks, the valves are turned on and good water pressure is ocming out of them.
    I don't think this is related to the water pump pe say as for example when I set the cycle to only SPIN, again, press the start button and I hear the clicks of the relays inside but the drum (motor) never starts spinning. Also, how a bad motor woudl affect the water pump ? I measuered the volatage coming into the motor when pressing START on SPIN cycle and it is 110 VAC for a few seconds then it drops after hearing a relay click, is like the computer checks for something and it send sthe right signals at first but then it stops everytrhing.
  • Luis Perez
    the water valves are turned on and good water pressure is ocming out of them.
  • Luis Perez
    Luis Perez Jun 02, 2009
    Ok, I checekd the door sensor and it looks good, i even took it out and bypassed it faking a closed door and nothing...
  • Luis Perez
    yes, what you are saying makes sense excet that I called Sears the authoized service representatvie fro Kenmore appliances and after checking a couple of meaningless things the tech that came overstated they can't fix this problem so i took it on my own because I know it can be fixed. I am a computer engineer and I am familiar with electronic boards and microcontroller components and I am extremely frsutrated at all this.... any otehr tips ?
  • Luis Perez
    so far all solutions provided have things I have already tried or knew. Nobody has provided a real clue or tip.
  • Luis Perez
    where do I find the water level switch ? or what does it look like ?
  • Luis Perez
    the thing is that if I place the cycle for SPIN only where no water level is involved the washer does the same thing, clicks of relays going on and off and nothing...
  • 864 Answers
If you are seeing voltage at the motor but it is not starting then the motor or the starting relay on the motor has failed.  A motor starting relay will close a contact that keeps the motor running after the initial signal is sent.  You said however that the washer is not filling up.  The start signal should open the fill valve to admit water and does not rely on the pump to fill.  The water level switch should tell the motor to start when the water level has reached the selected amount.  Check the valve and water level switch first.  If they are OK then the motor or motor relay are suspect.
Posted on Jun 02, 2009
  • John Morganti Jun 02, 2009
    I would need a manufacturer's name and model number to find a parts diagram for a specific place to look on your washer.   Usually the water level switch is outside the tub/drum.  Since you talked about a door lock I am assuming you have a front loading washer.  The switch will be at the bottom or side of the tub.  you have to  look underneath or remove a side, front, or back panel to see it.  It will look like a tube running up the side of the tub with a switch on it or like a diaphragm with a rubber tube running to the switch.
    If not spin when water is not required then the motor or motor relay has failed.
  • 3,267 Answers
Yes it is one or more sensors which are not being recognized by the replaced control panel. Think of it as if its brand new and configure/set all the settings otherwise it will have to be connected to a PC at the Authorized service center and the PC there will set it properly. Even if one sensor does not respond as expected, the machine simply won't start..........sodeep
PS: If you have the expertise then you can configure it yourself but I would not recommend that unless you are sure of what u are doing. The manufacturer will bear no responsibility if handled by anyone other that their trained technician. So please proceed accordingly.
    Sergeant:
  • 273 Answers
It's worth checking the door lock sensor as i had a similar problem relays clicking ect.. and found the sensor wasn't registering that the door was shut. before trying to replace it give the door a good push after the relay click. Hope this helps
Posted on Jun 01, 2009
    Brigadier General:
  • 3,917 Answers
Also would Highly appreciate if you go through the link provided bellow step by step and word by word to filter out the problem areas as the sysmptoms you have mentioned has several reasons.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Thank You
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Why didn't the diagnostic test work?
Sounds like one of the sensors is giving a false indication. If you don't get help here try getting advice at RepairClinic.com
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
My washer ( Whirlpool Cabrio M: WTW6500WW) will not start, cancel, rinse nothing! I can't even properly diagnose it because every button I press gives me an error chirp?
it sounds like you have a bad touch pad,try unplugging the machine for a few minutes to see if it resets the board,i would call the factory on this,they've been having problems with this and they might give you the part for free but you'll have to pay for the labor.
http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10070060/1202650
this could be the problem
Mar 29, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer stopped working.
Maybe that lid switch. Really hard to say without a model # to see how it's designed.
Sep 21, 2017 | Maytag PAV2300 Top Load Washer
It just stopped all led lights come on when powerbutton is pressed but nothing happens when the start/pause button is pressed
Hi
Thanks for using FixYa. It seems you have to replace the control board for your washer. Please do revert with the manufacturers name and model no# for your washer for further assistance.
Thanks Rylee
Feb 07, 2010 | Washing Machines
Frigidaire Front load washer FTF2140FS
What is this a Speed Queen??? I need model & Serial Number.
May 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
