Car will crank but won,t start. Have fuel pressure battery is good. Do you think it could have jumped time or cam shaft sensor bad?
SOURCE: Car won't start/fire up
Check all the grounds sounds like what i had on my truck. It took a good mechanic to find it but it ran after.
SOURCE: crank shaft sesor/cam sensor problem?
If you had a fault with the crank sencer your car would not start.Sounds like the air flow meter is giving you the problems.
SOURCE: 2004 Kia Optima no start after timing belt, crank, cam sensor replacement
did you use aftermarket crank sensor? if so that might be your problem. dealer has several different ones, by providing vin number, but there is only one after market for all optimas 01-05. try to connect thick pink wire and thick orange wire together on the ignition failure sensor. you might have the same problem as me. good luck.
SOURCE: 2002 Kia Sportage will not start.
p0560 is system voltage problem. open or short between the battery positive and the ecm.CHECK ALL FUSES. dosnt matter what they are labeled under dash and under hood replace any that are bad and retry to start. no start then check voltage to ecm grounds to. i dont have a wireing diagram to give you but for a small fee or free the dealer can make you a copy.make sure all the wires that go to battery terminals are not corroded and are making good contact [verified with volt meter]. if after all checks ok then replace ecm. as a side note i havent had to change one ever.
Testimonial: "Thank you for the help. We will continue to check all fuses and wires."
