Question about Kyocera Copystar CS-1820 Black and White Copier
PAPER TRAY JAM
THE PAPER JAMS FROM THE TRAY ONLY NOT THE BY PASS FEEDER.
    President:
  • Kyocera Master
  • 990 Answers
Hello sir;Pull out the tray look inside the machineif you found any paper chip emove it otherwise clean out paper pickup roller with rubbing alcohol.
Posted on Jun 01, 2009
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
I keep getting paper jam on my copier, tried cleaning the tray and feeder compartment but still the jams and squeezing of paper. what should i do pls
Try it from another paper tray and see it if still jams. IF it goes through, your first tray needs a roller cleaning or new rollers. Is it jamming out of the cassette or up into the fuser?
Feb 11, 2010 | Sharp AR-275 Copier
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
My fax machine/printer is saying i have a paper jam. there is no paper jam. i am looking in and throughout this machine. i need to print important papers on a daily basis. i need my machine fixed or a...
Normally the machines are right about paper jams, no matter how small a piece of paper it is.
Check in feeder tray, open all doors, look under rollers....etc.
Nov 19, 2008 | Lexmark Office Equipment & Supplies
HP 4 printer jam
I dont' think there is a site that exists. If this is a paper jam that occurs every few pages or so...you most likely will need to replace your pickup roller (located up under the machine after removing the cassette
Aug 26, 2008 | HP : HP4 Laserjet Printer
Kyocera Copystar CS-1820 Black and White Copier Logo
156 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
