Question about Jetway (MINIQ 860TWIN) Barebone
Pc turns on but no display on monitor
The first time i go to use the computer and it turns on but no display on monitor what shall i do. ive tryed the onboad graphics and a agp card nothing still and bios reset. please help my Pc seems to have every running on well but the monitor recieves no display...I tried the monitor with other PCs and all i workin well...I also tried my PC with other monitor but still notheing is diplayed, no beeps even if without RAM, what could be the problem with my PC and the possible solutionms to it?
  • 11 Answers
It sounds like the screen refresh rate is set to high. Try to plug in a monitor that you said works with the computer. If you have windows xp:
1) Go to the Control Panel
2) Select the Display icon
3) Select Settings then Advanced in the right corner
4) Select the monitors tab
5) change the screen refresh rate to 60
Click OK twice and close the control panel. Power off the pc and then change the monitor to the original one. Please let me know how this works for you!
Posted on Jun 01, 2009
Fixing color on moitor
sir please change or plug and unplug your VGA cable.
Oct 09, 2012 | Compaq crt monitor v570 - display - crt -...
My brother was messinng with the resolution settings and now the screen is stuck at imput not selected aand ive tried restarting it and making sure the cables are tight
Clarify me your monitor to post you back the correct settings.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Computers & Internet
Monitor turns off by itself during normal usage.
There are a few things you can try in order to narrow the the cause. First there's the easy outside-the-PC stuff such as:
- hook up a different power cable
- hook up a different video (VGA/DVI) cable
- You can always try switching to the other type of cable (try VGA if you're on DVI and vice-versa) to see if that makes a difference, assuming your monitor as both connectors.
- try connecting same monitor (and power/video cable) to a different PC for a day and see if it turns off there as well.
- For that matter connecting a "known good" monitor to your PC to see if that monitor also acts that way on your PC.
On the software side you can disable the power management features related to the display to see if that makes any difference.
If you were to connect this to a different PC with a different VGA/DVI cable and power cable and it still did it that I would say it's probably the monitor itself (unless the PCs were identical or something and under control of the same domain policies or some craziness like that).
At some point you probably want to call the manufacturer and see if an RMA is an option. I would recommend trying some things before that though. I hope this helped!
Jun 02, 2010 | Samsung SyncMaster 2220WM 22" LCD Monitor
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
LCD Flatron 21inch going into power save mode problem
this is not a problem with the monitor, it looks as your computer is not sending any video signals to the monitor thus it goes into saving mode. Take a look at the computer, check the video card. Pull it out then turn it on, turn it off again and place the video card where it should go then turn the PC on again. This should clue the OS to re-configure the video driver. Did you try another monitor ?
Jun 03, 2009 | LG 22" FLATRON LCD Monitor
Syncmaster 203B LCD not working with Vista 64
I would first recommend reseting the bios, if the monitor still is black then it may be a problem with the graphics card
Dec 16, 2008 | Samsung SyncMaster 203B LCD Monitor
I want to permentely turn off degauss mode in my monitor
Do you have everything plugged into a surge protection power strip?   If not consider getting one, as this will eliminate the Voltage Spikes which may be caused by everything coming on at the same time.
Nov 15, 2008 | LG Flatron 776FM 17" CRT Monitor
Monitor not coming up
try unplugging the monitor cable from the computer and check if you get a power on self test displayed
if yes then the monitor is fine we have to troubleshoot the computer
and if nothing is displayed the monitor needs to be replaced.
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
hi, need some help. when i turn my computer on i have lights and fans working, no beeps and no display.monitor is working fine with another comp. any ideas? thanks ... hawkeye.
Mar 14, 2008 | Jetway (MINIQ 860TWIN) Barebone
Jetway (MINIQ 860TWIN) Barebone Logo
228 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
