Question about HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 Language reset
The language on the printer menu has been set to Spanish. Unfortunately I could not find any step-by-step guide on how to set it back to english and I would need it as I do not understend a word of spanish and the users manual states the the language cannot be reset to factory settings. Help pls! Thank you very much:) The 1610 display is in an unreadable language; I cant tell what part of the setup menu i'm in and cant get it back to english. Thanks
  • 489 Answers
Press the Setup button until you see Preferencias and press OK. Press the right arrow until you see an entry with Lenguas in it and press OK. Use the left and right arrows to scroll through the languages and press OK when you find the one you want. When prompted press OK for yes or Cancel for no. Use the right arrow to select the country/region for the language you selected and press OK. When prompted, press the right arrow to select yes or no and press OK.
Posted on Jun 01, 2009
The language shown in the dispay window has changed to Spanish. How do I return it to the default language (English)?
The way was hidden somewhere in the HP solution center:
1. Press the cancel and power buttons at the same time, while the printer is on.
2. Press the blue, green and gray buttons (in this order)
3. Change the menu options with grey button until you get to the "Resets" menu.
4. Press OK. "Country and Language reset" displays.
5. Press and hold OK for approx 2 seconds, then release. The printer will turn off.
6. Start the printer again - it should ask you to select language.
Aug 09, 2011 | HP PSC 1610 All-In-One InkJet Printer
My H-P PSC 1610 All-in-One InkJet printer did this a couple of years ago and I fixed it but can't remember how I did it. The display is displaying unintelligible characters. I've turned it off, waited,...
Hopefully you have a setup button, press this and navigate to preferences, select this and select set language & country/region, hit OK, english should pop up, hit OK again, hit OK for yes, USA should pop up, hit OK, hit OK for yes & this should take you back to set language & country/region menu. From there just keep hitting left arrow back to the display screen and you should be done. This is how it is done for mine, hopefully there is something similar to this for yours. Hope this helps.
If this does not help, the only way to setup English language is to do reset on the printer. By doing the reset, the printer will loose any settings you have already set in the printer ( does not affect any PC/software settings )
Steps for Reset
Disconnect the power cord from back of the printer ( while the printer is powered on )
While holding the power button and cancel button front panel, connect the cord back.
The printer will go through alignment process. Complete the alignment.
*Note : Doing this reset, you will loose any fax logs or settings set on printer
The printer should work fine. If the issue does not resolve, it could be hardware issue.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | HP PSC 1610 All-In-One InkJet Printer
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
How to reset fom japanese to english,hp psc 1610
1. Press Setup until Preferences appears (4th or last option), and then press OK.
2. Press right arrow until Set Language & Country/Region appears, and then press OK.
You are prompted with a list of languages. You can scroll through the list of languages by pressing right arrow or left arrow.
3. Press OK on the appropriate language.
4. When prompted, press OK to select Yes or Cancel to select No.
You are prompted with a list of countries/regions for the selected language.
5. Press to select the appropriate country/region, and then press OK.
6. When prompted, press to select Yes or No, and then press OK.
You can confirm the language and country/region by printing a Self-Test Report,as follows:
1. Press Setup until Print Report appears, and then press OK.
2. Press until Self-Test Report appears, and then press OK.
Verify the result
:) Dr Tony
Apr 08, 2010 | HP PSC 1610 All-In-One InkJet Printer
The language on my printer screen is spanish, I don't know how to change it to english
follow this steps Go to Menu > Maintenance > Set Language & Country/Region > Press Start for English > hope this helps
Sep 01, 2009 | HP PSC 750 All-In-One InkJet Printer
My hp psc 1610 is in chinese. I can't read it to fix it. Help!
Press setup button and use left arrow one time
set ok
Press right arrow for four time
set ok
press left or right till ur language displayed
press ok to set your language. Most probably English
Aug 24, 2009 | HP PSC 1610 All-In-One InkJet Printer
Press SETUP until you see 4. PREFERENCES. (Spanish-Preferencias) Press OK.
Press RIGHT ARROW until you see SET LANGUAGE & COUNTRY/REGION. (Spanish-Idioma & Pais) Press OK.
Press LEFT ARROW or RIGHT ARROW until you see ENGLISH. (Spanish-Inglés) Press OK.
When Prompted, press OK.
Press RIGHT ARROW to select the country. Press OK.
When prompted press RIGHT ARROW to select Yes or No. Press OK.
Here is a link to the User Guide. It's on page 93.
PSC1610 User Guide
Nov 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP psc 950
I would chat with HP, they should have one availible to walk you thruogh the change. UNLESS, you can read enough of the screen to change idioma [language in spanish?]
Jul 10, 2008 | HP PSC 950 All-In-One InkJet Printer
HP PSC 1610 prob
hmm okay hun
how did they change it from the printer
or from the comp?
Jan 07, 2008 | HP LaserJet 1020 Printer
HP PSC 1610 All-In-One InkJet Printer Logo
246 people viewed this question
Seeker5211
Seeker5211
