Question about RCA 27R411T 27" TV
No picture no sound just a whistling noise
I have an RCA 27inch tv set, i was just playing the tv yesterday with the DVD player, now when i tried to turn it on there is no picture nor sound, just a strange whistling noise coming from it. the front panel buttons are not working either?
    Problem Solver:
  • 6 Answers
Check flyback transformer and horizontal output transistor.
Posted on Aug 11, 2009
  • KV MAN
    KV MAN Aug 12, 2009
    Didn't I just say that, mie999s? For sure the horizontal deflection transistor is toast (probably an S2055), and it's likely the flyback failed causing the transistor failure.
    You can try just replacing the transistor (they are about $5) and see if that works, but if you replace both flyback and BJT, you should be good to go.
  • 105 Answers
Maybe the flyback transformer or horizontal output ic
Posted on Jun 07, 2009
No sound playing on rca 26 in tv/dvd combo
Have you tried going into sound settings and seeing if the sound output is set to Tv speakers and not external sound system?
Dec 02, 2011 | RCA Televison & Video
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture
How is the player plugged into the TV set? Are you using the S-video or RCA type plugs? Have you tryed a differant input on a differant TV? It could also be your cables. If you tryed differant cables and a differant input then your problem is a broken connection on the video jack or in the video output processor IC inside the unit and thats not a user fixable problem, Sorry. Good luck
Jul 23, 2006 | Sanyo DWM400 DVD Player
RCA 27R411T 27" TV Logo
349 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
