Question about LG DLG5932W Gas Dryer
Dryer runs but there is no heat. Clothes spin but aren't drying. Any help is much appreciated!
We have a DLG5932W LG clothes dryer. It is about 3 years old. The dryer runs, but there is no heat. Any help is much appreciated!
    President:
  • 1,776 Answers
On a gas dryer that will not heat, the first thing to check is the ignitor. The ignitor should heat up and glow orange if it is working. If not, the ignitor is defective. The next thing to check are the gas valve coils. These are electrical solenoids that are located just above the gas valves. When energized, they open the gas valves and allow the gas to flow to the burner and be ignited. If everything looks like it is operating well, but the dryer is still not heating/drying properly, the next thing that I would consider would be a faulty high limit thermostat. Sure hope this helped and best wishes.
Posted on Jul 31, 2009
One of the easiest things to check would be if the high temp safety has tripped. If this has tripped, you may have an air flow problem which is causing the dryer to get too hot. A vent cleaning may be in order if this is the case.
Posted on Aug 01, 2009
On mine it was one of the electromagnetic actuators on the gas valve.
A very inexpensive part, that is unfortunately not sold separately. You have to buy the whole gas valve. The good news is you can return it if it was not the broken part, even if you have installed it.
I got it hear and have no complaints what so ever about this site:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-DLG5932W-%3d%3di1266848&PartID=1266848
Posted on Jun 21, 2009
Sounds like the heating element is shot. Replace and happy drrying
Posted on Jun 01, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Heat level in dryer
A dryer usually overheats because of a kink or blockage in the duct work, blockage in the outside wall cap, or because of a defective cycling thermostat. The cycling thermostat tells the dryer when to heat and not to heat. Clean any lint from the inner and outer ductwork. You can also remove the vent from the back of the dryer for a load or two to determine if the clothes dry faster or not. If this doesn't fix it, go ahead and replace the cycling thermostat. Make sure to use the appropriate setting to dry the clothes.
Aug 09, 2008 | LG DLG0452W Gas Dryer
Clothes aren't drying...
First check and clean the lint trap. Next turn on the dryer and go outside to the dryer vent and make sure you have good airflow coming out. If you don't have good airflow then there is a blockage in the vent system somewhere.
Jul 26, 2012 | LG DLE7177 Dryer
I have a lg dryer that will not dry things all the way before shuting off. I sometimes have to run it 2 or 3 times
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Dryers
Seems to heat. I know it's spinning. Why aren't my clothes getting dry?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 18, 2011 | LG DLE5977 Electric Dryer
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
LG DLG5932W Gas Dryer Logo
1,026 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
