I use the focus lock by half pressing the button and then re composing the shot - when I last used my camera it stopped working and thought it might be the lens causing the problem but when I changed to a different lens it still wouldn't work - has anyone else had this - is it easily fixed or an expensive repair? - it is out of warranty now but I need to get it sorted quickly
for clarification: did you reset the setting of your camera?? try to remove the battery for an 1hour to self reset the camera..
if the above info did not solve the issue this fucos lock button is the problem. it is easily to fix, it can be reapirable or replace the lock button.. got no idea on the labor and part costing on your area but better to inquire it first to the nearest canon service center.
when i insert a fully charged battery the camera will turn on but it will not focus or fire when I...
(More)
when i insert a fully charged battery the camera will turn on but it will not focus or fire when I try to take a photo. also nothing will show on the screen when the menu button is pressed
When looking at images in the cardreader, extra folders appear with Chinese or Japanese symbols and...
(More)
When looking at images in the cardreader, extra folders appear with Chinese or Japanese symbols and large numbers of my images are missing. Is this similar to your problem and have you found a solution?
