I have windows vista with powerpoint 2007 i made presentation w/ video wav files and 42 slides it works fine on my computer every cd ive made and flash drive ive copied it to doesnt work..either video is frozen or black screen ( video is swf file and plays in my files) or some or all music doesnt play. the other systems trying to play this file are 97-03 versions. someone did the package cd thing for me and said it would play in all versions. on 1 computer a message came up as it not being a powerpoint file..what is wrong. i made it w/ macros enabled ( i dont know what it is but chose yes) is that the problem? if so how do i change that. my son's project is due asap and it is a final grade and i am running out of time. thanks
  • kmwarner345 Jun 01, 2009
    ive erased and copied to flash drive 4 times and have made 10 cds..all to no avail
    Sergeant:
  • 187 Answers
Hey..
I think u didnt save it in proper format...Just click save as and save it as a windows 97-03 doc or ppt..It ll work fine..
please rate my suggestion....
Posted on Jun 03, 2009
    President:
  • 1,383 Answers
No it not issue but the problem is files type try copy again to flash drive also check your flash drive is not virus infected.
let me know
Posted on Jun 01, 2009
Powerpoint can't open the type of file represented by........
1. Try some of the things listed below. But first make a backup copy of your presentation and use it, not your original file. Never try any of these recovery techniques on your only copy of a presentation.
Things to try:
-If you run PowerPoint 2003, choose Help, About Microsoft PowerPoint from the main menu bar. If the About screen doesn't indicate that you have SP1 (Service Pack 1) or higher, you should update your copy of PowerPoint. Choose Help, Check For Updates. When the Office Downloads page opens in your browser, click "Check for Updates" and apply the recommended hotfixes and/or service packs.
-If you run Windows XP and have installed SP1, see Files open as Read-Only after installing Windows XP SP1, Other file/path related problems
-Open a blank presentation (You can apply the template used for the damaged file, if applicable. That might help cut down on reformatting.)
-From the main menu, choose Insert, Slides from File (or if you use PowerPoint 2007, Home tab, New Slides (bottom of button), Reuse Slides.
-Try to insert slides individually if you're not able to insert the whole thing
2. If your file became corrupted when PowerPoint or your computer crashed, there may be a temporary version of the file in your TEMP directory. If so, you can try the aforementioned Insert, Slides From File and browse to that file. Or you can try changing the file's extension to PPT and see if you can open it from within PowerPoint using File, Open. You could also do a search for *.TMP files on the off chance that it's not in your TEMP directory.
3. If nothing else works, try opening the presentation in Word to see if you can at least recover the text:
-Start Word and choose File, Open
-Choose file type "Recover text from any document"
-Edit the file as needed
4. If all these three methods don't work, then use third party software PowerPoint Repair Toolbox https://www.repairtoolbox.com/powerpointrepair.html
Apr 13, 2015 | Microsoft PowerPoint 2007 for PC
How to make power presentatio?
  • If Office PowerPoint 2007 is already running, save and close any open presentations, and then exit and restart PowerPoint 2007.
Find links to information about saving presentations in the See Also section.
  • If Office PowerPoint 2007 isn't already running, start it now.
In the Slide pane, you can work directly on individual slides. za001093949.gif Dotted borders identify placeholders, where you can type text or insert pictures, charts, and other objects. za001093950.gif The Slides tab shows a thumbnail version of each full size slide shown in the Slide pane. After you add other slides, you can click a thumbnail on the Slides tab to make the slide appear in the Slide pane. Or you can drag thumbnails to rearrange the slides in your presentation. You can also add or delete slides on the Slides tab. za001093951.gif In the Notes pane, you can type notes about the current slide. You can hand out your notes to your audience or refer to your notes in Presenter view when you give your presentation. Note By default, Office PowerPoint 2007 applies the Blank Presentation template, which appears in the preceding illustration, to new presentations. Blank Presentation is the simplest and most generic of the templates in Office PowerPoint 2007. Blank Presentation is a good template to use when you first start working with PowerPoint because it is straightforward and can be adapted to many presentation types. To create a new presentation that is based on the Blank Presentation template, click the Microsoft Office Button za010077102.gif, click New, click Blank and recent under Templates, and then double-click Blank Presentation under Blank and recent.
After you open the Blank Presentation template, only a small portion of the Notes pane is visible. To see a larger portion of the Notes pane so that you have more room to type in it, do the following:
  1. Point to the top border of the Notes pane.
  2. When the pointer becomes a za010205206.gif, drag the border up to make a little more room for your speaker notes, as shown in the following illustration.
Name and save your presentation As with any software program, it is a good idea to name and save your presentation right away and then to save your changes frequently while you work:
  1. Click the Microsoft Office Button za010077102.gif, point to Save As, and then do one of the following:
    • For a presentation that can be opened only in Office PowerPoint 2007, click PowerPoint Presentation.
    • For a presentation that can be opened in either Office PowerPoint 2007 or earlier versions of PowerPoint, click PowerPoint 97-2003 Presentation.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
  1. In the Save As dialog box, in the Save in list, select the folder or other location where you want to save your presentation.
  2. In the File name box, type a name for your presentation, or do nothing to accept the default file name, and then click Save.
Add, rearrange, and delete slides The single slide that is provided automatically in your presentation has two placeholders, one formatted for a title and the other formatted for a subtitle. The arrangement of placeholders on a slide is called a layout. Office PowerPoint 2007 also provides other types of placeholders, such as those for pictures and SmartArt graphics.
When you add a slide to your presentation, you can do the following to choose a layout for the new slide at the same time:
  1. On the Slides tab, click just below the single slide that already appears there.
  2. On the Home tab, in the Slides group, click the arrow next to New Slide.
za001093948.gif The name identifies the content that each layout is designed for. za001093949.gif Placeholders that display colored icons can contain text, but you can also click the icons to automatically insert objects, including SmartArt graphics and clip art.
  1. Click the layout that you want for your new slide.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
Aug 17, 2011 | Microsoft Office Professional 2007 Full...
It's me again! i hade a problem: I would like to make a slide show for a dvd with pictures,and that repeats itself.what program,and how should i use(i have windows xp)!and after i would like put the disc...
Versatile and easy PowerPoint Converter
This PowerPoint Converter is a great Microsoft PowerPoint presentation tool that can convert PowerPoint to video and audio file in almost any formats. All the original elements in PowerPoint can be perfectly retained in this PowerPoint to video conversion, including animation, sounds, movie clips, transitions, internal links, and so on. PowerPoint 2007 is supported.
PowerPoint Converter can convert PowerPoint file to AVI, 3GP, 3G2, MP4, WMV, MOV, FLV, VOB, MPG, MPEG1, MPEG2, DV video and MP3, AAC, M4A, WAV, WMA, AC3, MP2 audio files for you to upload PowerPoint to YouTube, watch PowerPoint on iPod, iPhone, Zune, PSP, Apple TV, Blackberry, Creative Zen, PS3, Xbox, and more MP4, MP3 players.
The PowerPoint to Flash Converter can help you convert PowerPoint slide in to Flash video. You can input ppt, pptx, pptm files and get FLV or SWF videos. Then you can upload these video to YouTube, your Blog, your Space, and other websites to share with others.
Now, with the powerful PowerPoint Flash Converter, your files documents can be shown on the Web not only as a standalone document in a separate window but also can be embedded in a web page and shown inside it altogether with other web page content.
Here, the PowerPoint to PDF Converter can help you create PDF file from documents including ppt, pptx, pptm. It is easy-to-use software which can translate different doucment formats to pdf in batches once with ease.
To convert PowerPoint to PDF is easier than ever with this powerful converter. And only several clicks are needed to finish all the conversions with high converting speed and super good output quality.
The original style of PowerPoint files can be perfectly retained, and both beginners and pro users will find this PowerPoint to PDFconverter tool quite easy to use.
PowerPoint to DVD Converter mentioned in this part is an excellent converter from PowerPoint to DVD tool, that can convert PowerPoint to DVD video and burn PowerPoint to DVD, with rich DVD settings, supporting all sorts of DVD discs. Then you can watch PowerPoint on any DVD player.
PowerPoint to DVD Converter can perfectly retain the original music, animation, movie clips, and slide transitions of the original PPT files. And it allows you to insert background music, or record voice as the narrations and instructions for the PPT files.
You can also use PowerPoint to DVD Tool to create delicate DVD menus. It is the best tool to create a DVD from PowerPoint for playback on home DVD players. PowerPoint 2007 is supported.
Moreover, this versatile PowerPoint to DVD Converter also helps convert PowerPoint to all popular video formats like AVI, MP4, FLV, MPEG, 3GP, MOV, WMV, MPEG1, MPEG2, MP3, AAC, etc. Then you can watch PowerPoint on iPod, iPhone, PSP, Apple TV, Zune, Creative Zen Player, Black Berry, etc.
PowerPoint to JPEG Converter can convert PowerPoint to JPEG image file and convert PowerPoint slide to JPG picture file. It is the best PowerPoint JPEG converter and PowerPoint JPG converter, which is both powerful and easy to use.
Microsoft PowerPoint 2007 are supported by this PowerPoint converter, it can convert .ppt, .pptx, and .pptm files to all popular image formats with fast speed and excellent image quality.
PowerPoint Slide Show Converter,
PowerPoint to SWF Converter,
PowerPoint to AVI Converter,
PowerPoint to MPEG Converter,
PowerPoint to WMV Converter,
PowerPoint to MP4 Converter,
PowerPoint to FLV Converter,
PowerPoint to iPAQ Converter,
PowerPoint to iPod Converter
Aug 11, 2010 | Computers & Internet
How can I add a .wav file to an entire PowerPoint slideshow? I only know how to add sound to a single slide and want the file to play through the entire presentation. Thanks in advance for your help.
Since you have not mention the power point version that you are currently using I give you the method to embed sound in your entire slide show for both PowerPoint 2003 and PowerPoint 2007.
Lets start with PowerPoint 2003 : Go to the slide where you want to initiate the sound track in .wav form.(1st slide is the default).
Go to Insert> Movies and Sound> Sound from file
Select your .wav sound file and click ok.
After you click OK you will se a dialogue box appearing asking you "How do you want the sound to play". You have to specify that. If you are not sure select "Automatically" so when you land on that slide during the slide show your music or sound will start automatically.
Select Slide Show ->Custom Animation to enter the Custom Animation pane. Confirm Your soundtrack is listed below in the pane.
  • In the drop-down list of the sound, choose Effect Options. Then the Play Sound interface appears. In the Effect tab, click the radio button beside Stop Playing After XXX slides (which indicates how many slides you want this song to play across) to enter the number of slides you intend to add. For example, you can enter a number from 1 to 999 for this field. Then the sound will play throughout the specified slides.
  • Next, check the settings in the Timing tab. To play automatically, you can set to Start After Previous with a 0-second delay. Click OK to exit the dialog box.
  • Then go to Sound Settings tab, adjust the sound volume as you like. You can also tick to hide sound icon during slide show if you don't want it appear.
Now your sound will play from the first slide till the last.
Life is much much easier with PowerPoint 2007
  • On the slide, click Insert to pick the Sound drop-down list on the very right below the tab. Select Sound from File in the list and choose the specified sound track from your hard drive.
  • Click OK and a message prompts, saying How do you want the sound to start in the slide show? Click Automatically.
  • Now click the sound icon to display the Options tab. Click on the tab, and set Play across slides for Play Sound.
At the moment, it is time for you to play the entire slide show while enjoying this pleasant sound score.
NOTE:
  • The sound you insert must be as long as your slide show. That is, if the slide show lasts 5 minutes, your soundtrack should also be at that length. Otherwise, the sound would be cut off until the slide show ends.
  • It is highly recommend that you take PowerPoint 2007 for your convenience.
Jul 17, 2010 | Microsoft Office 2000 Web Components Book...
Cannot Load C.D w/ powerpoint presentation onto another computer.
Can you just transfer your file/s to a flash drive? Or there's issue of different version of office between two computers. Say your using office 2007 and save it on higher version, then the other computer uses office 2003.
Apr 20, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Linking sound wave files to PowerPoint
Hi Rose,
Instead of copying presentation directly to CD, simply do Package on CD (File menu --> Package in CD, then copy to a folder or directly burn to CD
it will contain everything required to run presentation your PPT file, Powerpoint Viewer and all supporting files.
any ways having problems pl contact me
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Mar 13, 2009 | Microsoft PowerPoint for PC
Powerpoint video problem
Does the videos play well in Windows Media Player? If not, it deciates that there are not proper codec installed on your computer.Try to download and install some new codec from official: http://www.microsoft.com/windows/windowsmedia/forpros/format/codecdownload.aspx. Go for codec references at: http://www.codecguide.com/
If the video plays well, please try the following methods:
Method 1.
1. Put video files and the PowerPoint presentation in a same folder.
2. Re-insert these files to PowerPoint presentation.
Method 2.
Insert -> Hyperlink, choose the video file you want to insert, and then click ok. After do this, you can click the hyperlink to view the video when present the slide show.
Method 3.
 1. Display the slide you want to insert video.
 2. Click the View menu in the menu bar, and then choose Toolbars in its child menu, later Control Toolbox to let Control Toolbox displayed. Choose More Controls which seems like hammer.
 3. In the succeeding dialog box, choose Shockwave Flash Object. Your cursor will change into a cross-hair - draw a rectangle anywhere on screen
4. Right click the inserted Shockwave Flash control, and then click Properties.
5. Click the Movie property > type the full drive path in the value column (the blank cell next to Movie), including the file name (e.g. C:a.swf) or URL (e.g. http://www.a.com/b.swf)
6. To make the Flash play automatically when the slide is displayed, set the Playing property to True;
7. Finally close the Properties window and save your presentation.
Method 4.
Convert your PowerPoint presentation to Flash use some third party presentation tools, PowerPoint to Flash converter, for instance.
BTW, the link: http://www.playsforcertain.com/tutorial.htm may help you.
Nov 04, 2008 | HP VP6121 Multimedia Projector
Hyperlinks in PowerPoint
it is because the compatible MS Office for windows vista is MS Office 2007. if you got a lower version, it is doesn't really work. try to get the latest version of MS Office.
Feb 26, 2008 | Microsoft Windows Vista Ultimate Edition
When i am doing presentation with microsoft power point2007
you have to have the music and movies files sent as well. try putting all the files in a folder (including the powerpoint file) and relinking the files in the powerpoint. then send the whole thing and you should have music and movies. try it on another computer if you want to make sure.
Jan 02, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
