I am 81 yrs old and need some help in getting someone to walk me through the steps required to get the printer to recognize my samsung chromebook. Thankyou for your help Bill
SOURCE: HP Deskjet 3845
Sounds like the color cartridge is overheating. Could be defective, ESPECIALLY if it not an original Hp BRAND NEW cartridge. Change out the color cartridge and see what happens. Each tiny little nozzle has its own heating element. Electronics monitor the temperature. Will stop the printing until the temperature comes back to an acceptable range. Ed
SOURCE: The printer is not recognizing
Your printer does not use #59 Cartridge!!!!
HP 56 black print cartridge (19 ml)
C6656A
HP 57 tri-color print cartridge (17 ml)
C6657A
HP 27 low capacity black print cartridge (10 ml)
C8727A
HP 28 low capacity tri-color print cartridge (8ml)
C8728A
SOURCE: Service required message
this may mean that your printer needs to be reset i have all epson reseters if you need them
SOURCE: Dell 924 printer won't work on vista OS
First, here is a link to the vista 32 bit drivers. Install these drivers if you have not installed them before.
Second, if you are using Vista 64 bit, Dell does not make a driver for the 64 bit O/S. You can re-install your Vista to 32 bit or buy a printer that is compatible with 64 bit O/S
