Question about Compaq Presario 700 470024-192 Notebook
Laptop battery wont charge, wont even turn on to charge.
My daughters laptop just suddenly quit working & will not come back on. we've tried a new battery .... no luck we've tried without battery....no luck we've tried different ac adapter...no luck mines doing that too. I was on the internet and it just stopped working. Everything just shut off. It came back on the next day, and it said the battery was charging, but then it completely died and now the battery wont even charge. Its bullcrap!
    President:
  • 2,992 Answers
A common trouble is that the solder joints from the power jack to the motherboard can break. This is due to flexing the power plug over time. When this happens the power can't get onto the board at all to run the computer or charge the battery. Sometimes the connections may still work, so you get the intermittent operation you mentioned.
Usually this can be repaired, but it means disassembling the computer to take out the motherboard and resoldering the connections. In some cases, the motherboard can be damaged by heating and arcing from the bad connections and can't be repeaired, but this is pretty rare. A computer shop might be able to do the repair if they get into that level of service.
Posted on Jun 01, 2009
I have a MicroExpress laptop model FL92 that I bought several years ago. Ever since I got it, I've had problems with it suddenly quitting without warning. It appears to be heat-related and has p
depending how computer savey you are, you could open it up . clean heat sink and apply new thermal paste to the processor. not too moch, but not too little
Jan 30, 2013 | Computers & Internet
I have a leapster2 that I just put brand new batteries in 2 days ago, it powered off suddenly while my daughter was playing and will not power back on. I've tried changing the batteries again and using...
Yes! take it back to the place of purchase, this is a manufacture issue. By the description it is a motherboard problem and should still be under warranty.
Aug 19, 2012 | Computers & Internet
Aswell as my daughter I've installed the drivers (Vista and 7) of the Lexmark x4550 wireless, but she can only print when my laptop is 'on'. How can she print without the use of my laptop.
All you need to do is to remove the printer currently added on your daughter's laptop(most likely it is the printer installed on your laptop)and then add the lexmark printer manually on your daughters laptop. Make sure when you do this your laptop is turned off. If this won't work, that means that the laptop of your daughter does not detect the wireless printer.
hope this helps...
Sep 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Hi... My 14 y.o. daughter has a Benq lap top (Joy book) which was purchased in Hong Kong 15 months ago. The other night, when she had it plugged in to recharge, we suddenly smelt a "burning...
hmm just ur power supply (battery) might have burned out if ur lucky
and if ur unlucky then ur mobo fried out also
so i would suggest is getting a replacement battery from a store that accpets returns (such as staples, best but or along these lines) and get a battery that replaces the old one. and if ur lucky the new battery would do the trick (this seemslike what happened)
if not.... just take the hard drive from that laptop and buy a new laptop and put the new hard drive in that laptop
or u can take it to a technician and ask him to see if ur mobo fried up and if its a real expensive laptop (probably is cause its a BEnQ) then just replace the mobo probably cost u around 150
Nov 09, 2008 | Computers & Internet
Starting the laptop
Unplug all external devices. Remove the battery and ac adapter. Then try again with just the ac adapter and no battery. If it works, turn it off and put the battery back in. Everything should be fine.
What your daughter did is absolutely harmless, unless your laptop is set-up not to go to standby mode then eventually hibernate when the lid is closed. In that case if it was put into a laptop bag while running it may have overheated. If that's the case it may need a motherboard or CPU, have it checked out.
Oct 21, 2008 | Sony Computers & Internet
Laptop
sound like a bad motherboard
Jun 26, 2008 | Computers & Internet
Ti-83 Plus weird display problem (detail included)
Warning the following tip will erase apps and programs from calculator!
The following will run the self-test mode
Press mode then press alpha then press s then press enter
If you want to get out of the self test press the on button in case you want to attempt to save/transfer apps, programs, variables etc.
The calculator will start to test itself it'll countdown and display numbers on the screen. It can get better sometimes other times a replacement of both the cr1616/cr1620 lithium battery and the 4 AAAA batteries work. Also ensure that you've attempted to clear out all the memory and reset the calculator. To delete all variables, tables, graphs, etc: Press 2nd button then press MEM then press 2 then press 1.
To reset the calculator press 2nd button then press MEM then press 7 then press the left arrow then press 1 then press 2.
Jun 03, 2007 | Texas Instruments TI-83 Plus Calculator
Compaq Presario 700 470024-192 Notebook Logo
204 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
