Question about IOGear GCS632U 2-port KVM Switch
Hotkey mode I have a Macbook Pro for computer 1 and a Dell desktop for computer 2. Everything is set up correctly and works, except I can't toggle between computers.I use a wireless Microsoft keyboard for mac. I have tried the hold clear, -, thing and it doesn't work. any tips?
  • cthurlow Jan 04, 2009
    I have exactly the same issue with the only difference is I am using a kensington Slimblade keyboard
  • respond Feb 13, 2009
    Same issue here. Have to shut down and restart computers to switch between the two.
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Posted on Feb 13, 2009
  • 42 Answers
Check for switching software update.
Posted on Dec 09, 2007
Using a microsoft wireless keyboard and mouse.mouse ok,keyboard stuck in hotey mode.uninstalled and installed software and even restored pc.stll dont work.any ideas?
Posted on Oct 21, 2009
  • 2,923 Answers
Toggling between the computers using the GCS632U? All you have to do is to quickly press the Scroll Lock button twice.
Holding down the Clear key and the minus sign, that is for invoking the hotkey mode. These steps should be done if your keyboard does not have a Scroll Lock button.
Posted on Apr 14, 2009
I'm in a search box and some one is talking on my computer?What is: currently on a heading level 2,inside of HTML content. On a text field inside a search box.
Hi SandraW , I want to help you with your question, but I need more information from you. Can you please Call +1(518)348-9393
Sep 26, 2016 | Apple MacBook Pro Notebook
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Jun 06, 2012 | Apple MacBook Air
I have a Dell inspiron 1525 and the screen is black. The system is booting into windows but nothing is showing. fn-f8 will not output the signal.
How do you know that the laptop is booting into windows did you connect to an external monitor
and if it did work on external monitor you could then uninstall the display driver in device manager or do a system restore and then when windows restarts it may load the correct driver ( if that is/was the problem )
If you are sure that it is booting into windows but cannot see anything you could try restarting pressing F8 while booting to get you into safe mode and see if that will show on monitor if it does you could uninstall the display driver reboot and hopefully windows will reload the correct driver
good luck hope this works for you
Oct 30, 2010 | Dell Inspiron 1525 Laptop
Connecting to a projector, presentation mode is
Try right clicking on your desktop, go to properties, then settings, you should see display 1 and display 2, right click on 2 and select attach.
If its not there press FN+F8 a few times, also look for the presentation software that came with your laptop and see if it has the feature to turn it on.
Oct 17, 2009 | Dell Computers & Internet
check ur audio drivers installed correctly or not, then check whether u connected the speakers correctly or not... goto control panel--> sound and audio devices. click that and check whether your sound card drivers are installed or not....
Jul 02, 2009 | Dell Dimension 3000 PC Desktop
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Jun 26, 2009 | Apple MacBook Pro Notebook
I just upgraded my linksys 54g to the Dlink DIR-655. I have a dell desktop running vista, and a MacBook Pro. I spent two hours on the phone with Dlink help desk, the level 2 person finally said he thought...
its because you have to set the desktop up from the macbook while the desktop is pluged in to the router , from the macbook see if you can bring up the ip from there . these linksys routers are kind of dificult to work with i have one my self
Aug 19, 2008 | Computers & Internet
I have a new dell laptop. I have connected an external monitor to the laptop because the screen is bigger. The monitor has been working fine with my other computer that died. This monitor I have also used...
To activate the external VGA port on the portable Press the Fn key + the F8 key. This is a 3 setting toggle
1. LCD only
2. LCD & External
3. External only
You just press Fn+F8 again to cycle thru to the next setting
Jul 08, 2008 | Computers & Internet
Open Questions:
See all IOGear GCS632U 2-port KVM Switch Questions
IOGear GCS632U 2-port KVM Switch Logo
2,689 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
