Copystar CS-1650 All-In-One Laser Printer Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 3100 I am in the initial phase of set up on my Copystar CS-1650. I have installed the toner(maintenance item U130), I then loaded the paper, and it asks me to "Output an own-status report (maintenance item U000) but when I go to do this it gives me a code of "System Error Main Switch Off/On 3100) ..... any help?
Anonymous
Level 3:
  • Master 622 Answers
  • Posted on Dec 26, 2009
Anonymous
Master
Level 3:
Answers
622
Questions
0
Helped
227215
Points
1525
Try a u906... if it happens again... then a u020 if it happens again reset firmware... if it happens again check your scanner lamp... if thats ok then you got main board and/or scanner board problem...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Anonymous
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on Aug 30, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
0
Helped
3511
Points
21
Turn it off then re do the process
1helpful
Triumph -Adler Dc 2020 with Error code c 710 please help?
Toner sensor problem or Developer problem Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Troubleshooting a Copystar CG1505 with an error code of C710.
C710 Toner sensor problem
Try removing and refitting drum and toner.
If that doesn't help the toner cartridge or sensor is damaged.
Please take a moment to accept and rate this solution accordingly.
Thanks,
Lee
3helpful
Error code c6000 of copystar cs1815
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
After I follow what ottoman23 said, the machine is now saying that I have error code C6000. What is this?
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function). Also see note at bottom.
Purpose
Method
Completion
Replaced toner and waste toner container, but there is still a 'add toner' red light
6. Enter the maintenance item number (130) using the up/down keys.
7. Press the enter key. A selection item appears.
8. Select On using the up/down cursor keys.
9. Press the enter key.
10. Turning the power switch off and back on. ADDING TONER is displayed and installation of toner starts.
11. After approximately 15 minutes, the installation is completed and the machine becomes ready.
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
2. Select On using the up/down cursor keys.
4. Turning the power switch off and back on.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
C710 Code on Copystar 2030
if this does not help you may have damaged your toner cartridge or the sensor
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
