Question about KitchenAid KSRS25IL Side by Side Refrigerator
Freezer freezes fine/ Cold air not getting to Refigerator side
It seems the servo that operates the circulating air door won't open and let the cold air come into the refigerator side. Dont know if I shoud adjust cut in and out on switch or if the problem lies elsewhere. I don't here anything from the servo like it is trying to operate. I am gonna check for voltage next )if) I can get the plugs out of servo unit. Any sugestions?
  • Kevin D Oct 23, 2007
    I went ahead with your sugestion. I should explain that it hasn't been running for 24 hrs yet. We just purchased it from 2nd hand shop. It was supposedly been gone through and checked out. I have it so that I can see the doors on the top of fridge compartment and they won't open. Any sugestions
  • 4,889 Answers
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Oct 23, 2007
  • eagle338
    eagle338 Oct 23, 2007
    Ok this is a problem with the door assembly. One half of this
    assembly is riveted to the door hinge the other half is screwed to the bottom of the door.
    It is usually best to replace both parts at the same time. Both fridge and freezer doors
    have this type of a ride-up.
    Remove power, remove the upper hinge
    cover. Remove the upper hinge screws ( if the freezer door - disconnect the water line ),
    lift the door off the lower hinge and lay it down on the floor. The parts can be easily
    replaced now. See the picture below to see what the parts look like ( freezer
    hinge shown in the picture )....
  • eagle338
    Checkout the pic below
The freezer works fine but the refrigerator will not get cold.
On most new refrigerators there is damper that opens and allows the cold air from the freezer to circulate through the fresh food side.
I have seen this same problem caused by over stuffing either the freezer side and or the fresh foods side. On the sides of the fresh foods section there are normally vents which allow cold air from the freezer side to flow. If these are covered up, the air cannot circulate and without air circulation, the temp rise.
Both freezer side and fresh food side work because air is allowed to circulate around your product. I saw a refrigerator that the bottom half was 70 degrees and top half 38 degrees. The shelf about halfway down was completely blocking airflow. Threw out a bunch of boldly items and bags, rearranged items so air could flow and unit started working properly again.
If the damper is not opening, I have seen them freeze shut. It may have to be thawed.
There is also on some models a recirculation fan that gets turned on to circulate cold air from freezer. If this fan burns out or is blocked, it may need to be replaced.
You can go to searspartsdirect.com with your make and model number and get a complete drawing and parts breakdown for most refrigerators. And more important, you can buy them and have the part typically in two days at your door.
Hope this help!
Apr 19, 2016 | Refrigerators
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
GR-349SQF won't freeze
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
R
Jan 17, 2012 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator (GS6SHXLQ): Freezer does not working at all.
Jan 16, 2012 | Whirlpool Refrigerators
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
Freezer works fine but the refigerator does not get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 11, 2010 | Frigidaire FRT17G4B Top Freezer...
My side by side G E Sub-Zero is not getting or staying cold on the refigerator side, the freezer is working, what could be the problem?
check to make sure the damper door between the freezer and refrigerator is operating and not iced up so it can open fully to let cold air in from the freezer compartment
Dec 25, 2009 | Sub-Zero 632 / S
Freezer is not freezing properly and the refigerator is not cold
You have a defrost problem. The fridge gets cold air from freezer, if ice blocking from no defrost, no fridge temperature.
Apr 26, 2009 | Kenmore Refrigerators
GE Monogram freezer not freezing food & refreegiration side not cold enough
first thing to look for is the freezer fan running. then is the air circulating in compartment. blockage is a cause. themostat setting is important.you can leave freezer door open and trigger the door switch.you should feel cold air comming ot. i know it may sound silly check to see if freezer light goes off when shutting door. fan,circulation,cold air input.thermostat,lightoff. good luck
Jun 28, 2008 | GE Monogram ZISS480DRSS Stainless Steel
KitchenAid KSRS25IL Side by Side Refrigerator Logo
107 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
