Question about NEC MultiSync FE750 Monitor
Screen turns multi color then fades out and unable to use computer.Do I need a new one since the problem is in the led scr
My NRC Multisync FE750 fades to black after a few minutes. Disconnecting the AC cable for a few minutes allows monitor to return to normal for a few minutes, then fades to black again. It does the same thing regardless of which computer is attached to the monitor. Previously worked flawlessly. best rob After a few minutes on my computer screen turns a multiple colors then starts fading until the screen is white and freezes up.Do I need a new laptop since I cannot use it
3 Suggested Answers
SOURCE: Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Posted on Apr 05, 2009
  • 208 Answers
SOURCE: Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Posted on Sep 02, 2009
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
NEC MultiSync LCD2060NX does not power up
Not user servicable and with the low prices of new monitors - not worth the cost of the part.
Oct 29, 2009 | NEC MultiSync LCD2060NX (Bezel) 20" LCD...
The resolution notifier keeps popping up (NEC multisync 1740 CX) and I am unable to turn it off.
It probably is warning you that your video graphics adapator is puting out a non-native resolution to the monitor.
LCD monitors are designed for a specific resolution. If you don't use that resolution, the LCD has to try to mimick the resolution you've asked for.
Check your display settings and also consider updating your graphic driver if a new version is available.
Oct 13, 2009 | NEC MultiSync 1940CX 19" LCD Monitor
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
seconds.
9. This confirms that the radio signal is being sent and
received.
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
T30 Will not resume from standby without reboot
It sounds as if your computer is going into hibernation. Check your power management settings to see if keys are enabled allowing a specific key or process to bring computer out of hibernation. Hope this helps.
Dec 23, 2008 | NEC MultiSync FE750 Monitor
No display
When you get the red and green leds lit it means the screen doesn't see an input signal and has gone to stand-by. That the red led goes off when you reconnect suggests a signal has been recognised by the screen but be very aware that it may not be a good signal. As you are using a PC input I will assume the signal is RGBHV, maybe you have the H and V swapped around? I would try another computer source into the screen.
You say you are using the digital harness, please explain exactly what this is.
Feb 18, 2008 | NEC MultiSync LCD4010 40 in. Television
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
Screen and colors too bright
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
May 17, 2007 | NEC MultiSync 1920NX 19" LCD Monitor
Computers & Internet Logo
356 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
