Question about ATI RADEON 9550 Graphic Card
Graphics card how do i find out the size of my graphics card
  • 4,889 Answers
Re: graphics card
Which OS...Ok i will assume it is windows right-click on desktop
click properties, then click on settings tab, click advanced button, then click on adapter tab. You will get complete info about your graphics card..
Posted on Oct 23, 2007
0 characters
3 Points
ATI Radeon 9550
Brand of Graphic Chip: ATI
  • Bus Size in Bit: 128
  • Decoder: No
  • Direct 3D Compatible: Yes
  • Encoder: No
  • Firewire: No
  • GPU Model (Graphic Card): Radeon 9550
  • Open GL Compatible: Yes
  • RAM in MB: 128
  • RAMDAC Frequency in MHz: 400
  • Remote Control: No
  • TV Input: No
  • TV Output: Yes
  • Type: Graphic Card
  • May 07, 2014 | ATI Graphics Cards
    How do I replace the fan on the quadro fx 550 graphics card
    fans are relatively straight forward to replace. Assuming you have already bought a replacement correct sized fan. Turn off PC first, remove graphics card, unplug the small white fans power plug from the graphics card. there will be a couple of small screws holding it down, take them out. the fan should just come off. put new fan on by doing the above steps in reverse.
    Jul 27, 2012 | Nvidia Quadro FX 550, FX550, 128MB,PCI-E...
    Can i take the hardware from a small form factor pc case and put them in a bigger tower Or is the a decent graphics card that i can put in my ax1301
    Of course you can do that. And no, there are no decent graphic cards in that size - only old models intended for office use only.
    Sep 08, 2011 | Acer AOpen GF2Ti VO64 (64 MB) Graphic Card
    HP DL 330 advantage of AGP graphic cards
    the larger the size of the graphics card the better quality your gaming and entertainment programs will come out. however the graphics card cant always help if your monitor doesn't have a good enough display (480, 720, 1080p)
    Jul 13, 2010 | HP GeForce FX 5200, (128 MB) AGP Graphic...
    How 2 run the games which needed graphics card on my pc but i dont hav graphics card in my pc ? wat 2 do ?
    goto bios in advance tab select chipset increase buffer memory size pressF10 hit enter then try to play game
    Jun 26, 2010 | Graphics BV200 BizView 128MB (128 MB) PCI...
    Memory size is 64mb instead of 128mb
    it's beacuse bios,it's probably set to 64 MB,go to bios ,and set it to 128 MB,and instal latest drivers,and see will that fix it....
    Apr 10, 2010 | Nvidia GeForce FX 5500, (128 MB) Graphic...
    The characters are not clear they are blurry
    You should download and update the drivers for your graphic card from the manufacturer's website. However, you can also try changing the resolution of your display to the most viewable resolution instead, which will depend on your monitor size.
    Feb 27, 2010 | XFX GeForce2 MX 400 64 MB Graphic Card
    Problem in 8GB "Redwan"
    I'm very glade for this care of you. I take the programe in "8 GB" Kingstone and I foramat it by this prog. and find the analoge for size then the size become full ..............
    if you have any new in usb send it on my mail
    best wishes
    Eng, Redwan
    Jan 20, 2009 | Kingston flash memory card - 256 MB -...
    Hi, if you can not identify the size from info on the card then you need to run a diagnostic program such as pc32.
    You can obtain this on Hirens Boot disk.
    Google TSbay Warez and register here as a member [free membership] on this site you will find most Windows apps and Hirens boot disk is there.
    Goodluck, mistyman
    Nov 16, 2007 | Compaq NVS 280, (64 MB) Graphic Card
    ATI RADEON 9550 Graphic Card Logo
    22 people viewed this question
    Top ATI Graphics Cards Experts
    Brian Sullivan
    Brian Sullivan
    Are you an ATI Graphics Card Expert? Answer questions, earn points and help others
